Help! Brights indicator stays on!
Recently i had an issue with one of the wires coming loose on my headlight bulb connector so i picked up a new one at a local auto parts store. I got it swapped out pretty easy but afterwards anytime i have my headlights on (high beams or low beams) the high beams Indicator stays on and can't seem to find anything wrong
Sound like you switched the + with the - on the headlight socket. The headlights will still work, but it will likely cause the problem you are having. Is that possible you switched it?
that is a possibility. When i first looked i didnt know which wires were which, i then examined the wires. There were 3 wires which i knew were ground, low beam, and high beam. There was an orange wire, red with yellow stripe and red with blue stripe. I figured the orange was ground. I originally had a problem with my high beams but now low beams and I noticed that the red with blue stripe wire was coming out of the socket and looked like that was where the problem started so i figured that was the high beams wire. Does this not sound correct? The lights work fine switching between low beams and high beams
Tried referring to the other side but the wire connector i bought was aftermarket and looked a little diferent and just had labeled wires. Ill see if someone will lend me a multi meter and update you after i test it out.
