Help
Old Jun 27, 2008 | 02:05 PM
hovasong's Avatar
Help
Hello everybody. I am new to the forums I have a 2000 RL and I was wondering if I could get help with a problem. None of my Dash gauges work. When I stick the key in the green key light shows up also the battery light shows and then it cranks with no problem. Then there is one light that works on the whole dash and that's for the headlights being on. Other then that, there is no function out of the dash gauges.I have checked the fuse box under the drivers side. No blown fuses. I have also checked the fuses under the hood. No blown fuses. I also took the dash apart to see if there were any loose wires and such and found none. Hopefully You guys have an answer. Thank you.
