Heater problem. HELP!
Hey guys,
Today my heater just stopped working. It was set at 90 and was blowing nice and hot when all of a sudden it just started blowing cold air.
Do you guys know what the problem could be?? Thermostat maybe?
No idea, maybe you should change the coolant and see if that helps then change the thermostat.
Does anyone know the part number for the OEM thermostat.I experiencing some coolants leakage near the thermostat area after I changed the timing belts and water pump on my 96 RL. I need a new thermostat and thermostat housing gasket.
I've check with Autozone and all they have is Duralast thermostat, i've never use any Duralast products so I really don't they are good or not. Thx.
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
