DIY instructions for timing belt?
98 RL 194k miles
Any pointers or links to DIY instructions for replacing the timing belt, water pump and whatever other components are recommended (eg tensioner?)?
I hear you. I did the timing belt on my Saab V6 (dual cams) a few months ago and it was a job. However, I had detailed DIY instructions with pics from another Saab owner and it saved quite a bit of money.
It would be quite a save on your bank account if you did it yourself, but it'd be quite a headache to boot. Not to mention the other unforseen expenses such as the timing belt tensioner, and seals. I can get you a list of the parts that were done on my 04, if you like. It started as a tbelt, but when he got in there and tore it apar, he found other things.
Here's the part #'s and what I paid for them at a local acura dealer.
HP91212-PY3-003 OIL SEAL 00000 $9.40
AC14400-P5A-004 BELT 197RU24 B $62.02
AC14510-P5A-003 ADJUSTER $67.56
AC16176-P5A-004 GSKT, THROTTLE $4.30
AC31110-PY3-A01 BELT, ALTERNAT $18.13
AC38920-P5A-004 BELT, COMPRESS $18.82
AC56992-P5G-003 BELT, P.S. PUM $17.57
AC91213-PY3-003 2 OIL SEALS 35X50 $23.50
AC13440-P5A-004 BELT 69YU15 $23.40
AC19200-P5A-004 WATER PUMP $236.46
The water pump is the most expensive part. That thing is hyooooge.
Good idea to always do the tensioner as well as the belt. I also have Saab 9-5 V6 turbo. Saab offered 'free' timing belt replacement at the first interval (60k miles) but did *not* do the tensioners along with the belt. There were a rash of destroyed engines at 80-110k miles when the tensioner finally failed, snapped the belt and destroyed the engine....
For the small incremental cost one can avoid a very painful penalty for failure...
I like the 105k mi interval on the RL much better than the short one on Saab.
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
asahrts
Sep 4, 2015 05:55 PM
