changing intrument cluster
Old Dec 5, 2008 | 03:07 PM
drgkjaz's Avatar
8th Gear
98-rl...i have to change the instrument cluster as the speedometer does not work. i got a used cluster from the internet but wanted to what happens to the odometer reading when the cluster is replace and is there a way to set it to the right reading?
Old Dec 5, 2008 | 07:40 PM
Ken1997TL's Avatar
You'll need to take them to a speedometer shop and have them do the switch.
Old Dec 5, 2008 | 09:16 PM
drgkjaz's Avatar
8th Gear
thanks....are you saying the shop has to install the cluster? i.e., diy is not legal?
Old Dec 5, 2008 | 10:24 PM
drgkjaz's Avatar
8th Gear
PS...any idea what is typical charge for the switch?
Old Dec 8, 2008 | 08:41 AM
SeamusNH's Avatar
It is not that hard to swap out the instrument cluster. Go to www.pdftown.com and search on "acura rl". Download the tech manual (40 MB). There are diagrams and step by step instructions....
Old Dec 10, 2008 | 12:44 AM
Ken1997TL's Avatar
Its not too hard to swap it out. I've taken the dash completely apart and I've done the LED swap for the gauge cluster too.
The hard part is electronically altering the mileage. You need special equipment for that.
Old Dec 21, 2008 | 07:52 PM
MasterD86's Avatar
so it was you who bought the one on ebay! I check every so often since my odometer\trip went out, so I've been on the search for one that's close to my miles. wish there was a way to just fix that grrr
Old Dec 22, 2008 | 12:00 AM
97_RLer's Avatar
Ultimate DIYer
Let me tell you something important. You can buy any instrument cluster from 96-03 RL regardless of mileage if you just want to replace your non-working speedometer, tacometer, temp & fuel gauge, or odometer disply. The mileage information is stored on a ROM memory of the instrument cluster board. So, you can just swap the parts you need from working unit to your instrument cluster. Then, you will keep your mileage with everything working.
Go and get a cheap one on eBay. FYI, some temp & fuel gauge from 96-98 RLs doesn't have TCS light option although the boards have the feature the same to TCS version.
97_RLer
Old Dec 22, 2008 | 08:47 AM
MasterD86's Avatar
does the odo display come off the board in the cluster? I didn't check last time I had it out.
if so, drgkjaz hook me up with the extra!
Old Dec 22, 2008 | 11:34 AM
97_RLer's Avatar
Ultimate DIYer
I guess you missed my point. The odo display is just a display. It doesn't memorize any of your mileage data there. The current mileage information is stored on an IC chip on the instrument cluster board. Of course, you can take the odo display off the board easy.
Old Dec 23, 2008 | 09:17 AM
SeamusNH's Avatar
I sold the cluster for my car to a guy for $75. He had mileage that was higher than my car (over 300k). He said it was fairly easy to swap out...
Old Dec 24, 2008 | 05:32 PM
MasterD86's Avatar
oh sweet!! I did not know that. Damn wish I knew that when there were cheap clusters on ebay.
My problem is the display is shot on mine, so I just need a new odo display and back in business
Old Dec 25, 2008 | 07:32 AM
97_RLer's Avatar
Ultimate DIYer
If your odo disply is totally dark, either odo display inverter is dead or the instrument cluster board itself is dead. The letter you have to change the board result to loose your mileage information. You may check whether your odo display inverter is dead or not. If you can introduce a strong direct sunlight to the odo display with key on, you may barely see your odo reading. In this case, your odo display inverter is dead so you can just swap the display to fix it. Otherwise, your board is shot.
Old Dec 29, 2008 | 08:23 AM
SeamusNH's Avatar
There is one on ebay now. Check number 200291477723
Old Jan 1, 2009 | 09:56 PM
MasterD86's Avatar
ah ended, at a really high price,
but I looked at the odo with key in with direct sunlight on it, and could not see the reading. soo looks like the search for one closest to 130k is on
Dec 7, 2020 05:39 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
Sep 17, 2015 10:16 AM
brandnewcolony
Sep 12, 2015 10:39 AM
Aleax
Sep 11, 2015 11:31 AM
