Brake differences from 96-98 to 99 and up
Old 03-28-2013, 03:53 PM
pmendoza502's Avatar
just as the title states, Is there any differences? i need to replace one of my rear caliper brackets and pins cause one of the pins froze into the bracket, and rock auto has different prices and part numbers for the different years...
Old 03-29-2013, 09:43 AM
OLD_HATCH's Avatar
I believe in 99 they got larger brake rotors and calipers
Old 03-29-2013, 10:02 AM
2004 Carbon Gray 3.5RL
99blackhatch's Avatar
^^^ Correct.
The "Kouki" 99-04 model 3.5RL has larger calipers and rotors than the 96-98 "Zenki" model
Old 03-29-2013, 01:06 PM
is this both front and rear, or just front or just rear?
Old 03-30-2013, 09:32 AM
The TL wheels on the front end of my old '96... you can tell that the rotors don't fill the wheels like they do on the '04 as pictured below.
2004 brakes and calipers...
And here is a side view of the '96 as well... you also notice that the rear rotors are substantially smaller than those on the '04...
Old 03-30-2013, 05:50 PM
so from 99-02 are the rears the same size as the 96-98 or am i gonna to have to buy the slightly more expensive racket from rockauto? lolz
Old 04-01-2013, 08:49 AM
If you look at the Black '96 compared to the Gray '04... there is clearly a difference in size between the rears on them.
Old 04-01-2013, 01:17 PM
so 99 to 04 is all the same? or is there a difference between 99-01 to 02-04?
Old 04-01-2013, 02:12 PM
That... I do not know. I'll have to research and see if there is a difference in part numbers between the years
Old 04-01-2013, 02:47 PM
yea looking at parts geek, it seems there is only a difference from 96-98 to 99-04, but no info if there is any diff from 99-01 to 02-04
SidhuSaaB
05-30-2020 12:40 AM
blacktsxwagon
10-27-2015 10:12 PM
joflewbyu2
10-08-2015 11:16 AM
2ManyHobbies
09-24-2015 09:23 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: Brake differences from 96-98 to 99 and up
