blowed engine
Old Oct 26, 2010 | 06:11 AM
acura rl fan's Avatar
3rd Gear
blowed engine
when a head gasket blows at 150000 miles what would make that happen dos that come under any service recalls or any thing
also who know how much would the compression fall after 150000
my book says it should be 144 new would it stay like that high that long
thank for your help
Old Oct 26, 2010 | 02:11 PM
96acuraguy's Avatar
Head gasket failure
Usually overheating is the culprit. It's a gasket and they do fail. Compression is about seal...worn parts create less seal.
Old Oct 26, 2010 | 06:36 PM
3rd Gear
do you think it would be worth to rebuild if it overheated
or get a engine
Old Oct 26, 2010 | 06:44 PM
OLD_HATCH's Avatar
headgasket....overhearting is usually the coulprit.
150k is way past warranty. if your rings are good you should probably be higher at 150k from deposits.
get an engine with low miles n warranty
Acura9915
Feb 24, 2020 01:27 PM
Aug 15, 2019 12:58 PM
Rachel Lu
Sep 27, 2015 09:53 AM
mv01
Sep 15, 2015 10:36 AM
