Anyone parting a 97 RL?
Old Jul 5, 2012 | 11:49 PM
Mid-Cal-RL's Avatar
9th Gear
I was having a problem with what I thought was my main relay...turns out one of the connectors that plugs into the main relay is causing a short and thus blowing the relay. Rather than trying to disect and repair the connector, I will just splice in a replacement.....so, I am in need of the connector and around 2-3" of the wires.
Also, can anyone tell me what years would match up the same so junk yard hunting might be more fruitful?
Any help is appreciated....
Old Jul 6, 2012 | 11:56 AM
MyNameIsEarl's Avatar
Anything from whenever the RL started ('96, I think) to '98 should be a sure bet. '99 to '04 probably wouldn't hurt to look at either.
Old Jul 14, 2012 | 10:49 PM
Mid-Cal-RL's Avatar
9th Gear
Redline out of Sacramento has several 97 RL's they are parting and hooked me up with what I needed at a very reasonable price....parts are on the way.
Old Jul 16, 2012 | 07:45 PM
Glad to hear that you got your parts! I also have a wrecked 98 RL in my garage at the moment, so if there is anything you need that is more expensive elsewhere, I could probably send you the part, or maybe a trade. (I'm looking for a beige sunglass holder, stupid things breaks.)
Old Jul 16, 2012 | 11:49 PM
3.5RLv-tec?'s Avatar
My broke too. Do you still have the instrument cluster bezel by any chance
Old Jul 17, 2012 | 05:43 PM
Also, do you have the button between the high beam and the rear defrost? I installed an aftermarket HU and I accidentally threw the button away
[IMG] Uploaded with ImageShack.us[/IMG]
Old Jul 18, 2012 | 10:42 AM
I actually don't have parts that go for the radio/air-conditioning control, because the one that was crashed has the navigation system. And the buttons are not the same size for the two cars. But, if I do end up being able to install the navigation system, I could probably get it to you. Although, you may be able to get it quicker from a pick-your-part place, i'm sure they'd probably only charge you like fifty cents or so.
csmeance
Jan 7, 2026 06:25 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Ny1718
Sep 11, 2015 09:21 AM
hand123
Sep 10, 2015 09:29 AM
hand123
Sep 10, 2015 09:27 AM
