99 RL Starts then dies
Currently have a 99 RL and I've have thrown so much money at this car 🤷 I'm about to scrap it 😭. Every once in awhile it would die mid drive and would start back up. Now it started acting like it was missing upon acceleration. No miss codes showing, idle control error, replaced that today and now it just dies after 45-2mins. Cold start takes about 3 mins and it shuts off. I see stuff about the ignition switch being the cause. My alternator acted like it went out for about 2 days and started working again idk if this has anything to do with the issue but I need help 😭. This car only has 88k original miles.
I'd check the PGM-FI main relay. They go bad a lot and cause random issues like misfires and long starting as well as non-starting. If that doesn't work then check the fuel pump. If that doesn't work then check power and ground connections throughout the car. If that doesn't yield anything, then sadly it appears she will be off to heaven.
I think I found the problem today when it died on me again, fuel pump resistor located inside the trunk 🤷. I found out when it dies my fuel pump goes quite lol. I hear the relay clicks but no pump. 15 mins later try the car again and fuel pump kicks in and runs fine. It makes sense now when I try to accelerate it's almost like the car is running out of gas 🤦. The resistor is so hot to the touch that I think it's shutting down my fuel pump!
Also found out that that part is discontinued for this car so it looks like it's going to be a eBay scrap find 😳.
