96RL driver's side power lock and remote trunk problem
Old Apr 26, 2005 | 08:03 PM
lcnacura's Avatar
It happended again!
The driver's side door lock and the remote trunk button just went out again.
Can't open the trunk and unlock the doors from the driver's side. Very annoying
Last time it came back in a short period of time and don't know why.
Any suggestions? Thx
Old May 6, 2005 | 10:39 PM
MattB's Avatar
My Infiniti did something similar and it turned out that the switch controlling the door locks was bad. That's the first thing I'd look at.
Old Jan 18, 2006 | 04:42 PM
RICHBOOGIE141's Avatar
7th Gear
check the master switch on the drivers side .the trunk button doesnt work neither so pull the drivers door panel off and get a digital volt ohm meter and remove the switch and check if power is going in and if not it could be a fuse or a loose connector in the door . this probably has to be checked for corrosion or bad contacts . get back to me and let me know what happened
Old Jan 18, 2006 | 04:48 PM
7th Gear
check the master switch on the drivers side .the trunk button doesnt work neither so pull the drivers door panel off and get a digital volt ohm meter and remove the switch and check if power is going in and if not it could be a fuse or a loose connector in the door . this probably has to be checked for corrosion or bad contacts . get back to me and let me know what happened.dont automatically think its a bad switch most of the time its something very minor and people always go and spend on parts when its something u can find with a little patience
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
acura_dipset_tl
Jan 1, 2016 03:02 PM
PortlandRL
Sep 14, 2015 12:01 PM
