2002 acrua rl window regulator installation issues
Old Sep 17, 2021 | 04:48 PM
Davy Jones's Avatar
Hey everybody. First time posting on the forum. So to the point though I'm trying to install new rear window tracks and regulator motor assembly
, but its giving me hell. either the track will line up perfect and I cant get the motor to bolt up or the other way around. iv try several combination of bolting it in to get the play i need. and it isn't a a lot but no luck. Any ideas
Old Dec 3, 2021 | 12:31 AM
3.5RL dude's Avatar
if you havnt solved your issue yet i found to get the regulator in its easier to hold up the window in the fully closed position w some tape over the top of the door and to make sure the regulator is in the most up right position. plug it in before you install it and push the up button till it stops. then put it in it should line up almost perfect w the two screw holes that hold the glass. there are access holes at the top of the door to get your socket and bolts through.
Jakedasnake
1G RL (1996-2004)
Jan 9, 2021 01:47 PM
curlywurly
Oct 1, 2019 01:49 PM
Zzzz
1G RL (1996-2004)
Aug 12, 2018 12:53 PM
cbrig
1G RL (1996-2004)
Jul 18, 2018 09:09 AM
jeffsoderberg
1G TSX Problems & Fixes
Apr 23, 2017 11:58 AM
