Which tires?
Old May 13, 2011 | 10:43 PM
Mr. Leg's Avatar
4th Gear
Which tires?
New here.
I just wondering what you guys think is the better choice.
I am looking at replacing my tires on my 08 RDX. until now I have had the stocks. I was looking at costco. I like the Nitrogen and unlimited tire rotations.
so the only 2 choices I have are the OEM or Bridgestone Alenza. With the Michelin 70 instant rebate its about 130 difference. and I know I just missed the bridgestone rebate.
what what do you guys think is the better choice. Also I need this asap so I cant order from tire rack. Or does anyone have a good place in socal that has good prices on tires?
Old May 14, 2011 | 05:05 AM
gungho_15's Avatar
Have you tried Discount Tire? I have had excellent service from them! They have also matched or even beat Tire Rack prices. Plus they install!
Old May 14, 2011 | 01:18 PM
Mr Marco's Avatar
+1 And they are usually lower than Costco.
Old May 14, 2011 | 03:36 PM
VQPower37's Avatar
go with the bridgestone alenza ... have them on my sequoia and i love em
Old May 15, 2011 | 12:11 AM
Mr. Leg's Avatar
4th Gear
Thanks for the suggestions. I went with the bridgestones. Went to American tire for 808 out the door.
Are these supposed to be the same psi as the oem. They filled them to 35-38 psi.
Old May 15, 2011 | 03:20 PM
jbillakdsm's Avatar
No. If you look at the OEM tire max psi it was probably 44. The Bridegstone has a max psi of 51. They have a softer sidewall so you need the extra air to maintain the sidewall rigidity.
I got my RDX with the Alenzas and the dealer had 32 psi; they looked and rode like a half flat tire. I pumped up to 38-40 and they run great. I also improved my gas mileage by 4 mpg over the dealer setting. I've got 16K on them with virtually no wear and I do a rotation with each oil change in my garage.
Old May 16, 2011 | 08:24 PM
Mr. Leg's Avatar
4th Gear
awesome thanks for the info, I will make sure they are all in the 38-40 range.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DidiBob
Jan 4, 2016 12:41 PM
Robospinner
22
Sep 24, 2015 08:47 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
fallacy
Sep 4, 2015 10:15 AM
