Tire sizing for winter
Old Nov 4, 2010 | 07:02 PM
RDX_NRG's Avatar
Hi,
I have a 2008 RDX Technology Pkg. so it has tires size of 235/55/18. I am thinking about getting winter tires and i am torn between two sizes of tires for winter. I know that thinner winter rims are recommended but with thinner rims, handling is given up. Which size would you guys recommended for WINTER TIRES.
215/65/17
or
225/65/17
I live in Edmonton, Alberta Canada so the winters here are deadly.
Thanks in Advance.
Old Nov 8, 2010 | 01:14 PM
levic900rr's Avatar
I'm in the same boat, looking at putting some 16's on off an RSX. I had used them on my TSX, I'm going to try them tonight I'll let you know how it works
Old Nov 9, 2010 | 02:26 PM
Chas2's Avatar
FWIW, 215/65-17 is a lot closer in rolling diameter than 225/65-17.
Assuming 17 inch wheels fit, and I have no idea if they do, then another question would be, which tire is cheaper? And within each size, which has more choices?
Either size will work, but 225/65-17 is farther off in rolling diameter than 215's
Oh and by the way, you are interested in narrower tire section widths, not thinner rims. Typically a thinner rim would be a narrower width rim. That being said, with a 215 section, you could actually reduce your rim width from 7.0 to 6.5 inches.
Old Nov 9, 2010 | 03:07 PM
Mr Marco's Avatar
There are a couple of other posts on this subject:
https://acurazine.com/forums/showthr...t=winter+tires
Old Nov 13, 2010 | 10:22 AM
levic900rr's Avatar
To report back, the wheels off an 06 RSX will fit the 08 RDX. I just test fit them, front and rear. I'm ordering tires and TPMS valve stems on Monday. The thing should look beafy with those little wheels and more rubber!
Old Nov 13, 2010 | 08:11 PM
Chas2's Avatar
Make sure the width of the wheel is adequate for the tire.
Old Nov 14, 2010 | 06:33 AM
levic900rr's Avatar
Good call man, looks like Cooper recomends 6.5-8.5" rims for the 235/65-16's so my 6.5's should be fine.
Old Nov 15, 2010 | 03:23 PM
levic900rr's Avatar
Found some TPMS sensors on this site used for sale, and ordered some ST2's. Should have them mounted up this weekend.
Old Nov 19, 2010 | 07:06 AM
levic900rr's Avatar
Just got my TPMS valves. Tires are in...
Old Nov 27, 2010 | 11:32 AM
levic900rr's Avatar
In case anyone cares... RSX wheels will fit on an RDX.
Before...
After...
Old Nov 28, 2010 | 10:28 AM
Boostin''s Avatar
Boost Junkie
Just had a set of 17" Acura steelies and Dunlop SJ6 studless snowtires (225/65-17) installed. These tires in particular are a dedicated LT/SUV winter tire and came highly recommended by both the Acura dealer and a local independant tire shop I checked out as well.
Old Nov 28, 2010 | 05:56 PM
levic900rr's Avatar
Looks good man, do you mind if I ask what those Acura Steelies set you back?
I have been running Cooper ST2's on my vehicles for years and LOVE them.
Old Nov 28, 2010 | 07:48 PM
Boostin''s Avatar
Boost Junkie
One of my conditions for buying the RDX was that they supply, free of charge, a set of winter wheels/tires, so I don't know the exact price of the package they gave me (17" steel wheels+snowtires+TPMS+centercaps+new lugnuts) other than it was somewhere in the 1400$ (Canadian) range.
Old Nov 29, 2010 | 05:18 AM
levic900rr's Avatar
Good deal man, sweet looking ride.
Old Nov 29, 2010 | 11:50 AM
Mr Marco's Avatar
Very nice. That is even better than free all weather floor mats.
Old Nov 29, 2010 | 12:06 PM
Boostin''s Avatar
Boost Junkie
Thanks, the whole deal went down as $1500 off MSRP, plus that winter wheel/tire setup, so I saved roughly 3G's overall. I did have to buy my own winter floor mats though LOL!
Old Nov 30, 2010 | 02:10 PM
juiceyjc's Avatar
6th Gear
I am probably late to the party, but in my personal opinion, I like to stick with OE sizes. Yes, you can use 225/65R17 say a Blizzak WS70 or a Mich X-Ice XI2. Or even pop on a 225/60R18. But unless you have another set of rims its a pain in the a$$. Plus you got to reinstall the TPMS. Right now, I got some 235/55R18 Blizzak DM-V1. In my personal opinion they work great! A solid LT/SUV snow tire. I am really digging these right now, look and feel. Have some other friends that use them on their RDX and got great results....just waiting for the first snow fall in NJ!!
Josh
Old Nov 30, 2010 | 02:31 PM
Mr Marco's Avatar
^ I really wanted the Blizzaks, but the wife insisted on studded snows. This will be my first Hankook.
Old Nov 30, 2010 | 06:23 PM
levic900rr's Avatar
Josh
I just went with the 16's cause I have less money into the wheels (already had them) / tires / TPMS then I would have had buying one set of 235/55-18's Plus now I can swap tires in my garage in about 20 mins. It allows me to run my summers much later in the year too
Old Dec 1, 2010 | 10:40 AM
Mr Marco's Avatar
^Smart
Old Apr 16, 2011 | 05:28 PM
cambo21's Avatar
I have the same situation as you. I just traded in a 02 RSX type S for a 07 RDX. How did your 16" winter tires fit on them and how was it during the winter? I was going to sell my winter tires from the RSX but after reading your post I will just keep mine.
Let me know please, my winters aren't as bad as yours, I'm from Southern Ontario
Old May 21, 2012 | 01:26 PM
mtxjohn's Avatar
Correction
Those are 16" wheels from a 2002-2004 RSX. The 2006 have a 17" for the type s and 16" split-spoke for the base model.
So TPMS works in that wheel? Did you use factory sensors>
GhostTL09
Sep 19, 2015 01:57 PM
coykiam
Sep 11, 2015 03:43 PM
fallacy
Sep 4, 2015 10:15 AM
nuldabz
Sep 3, 2015 05:49 PM
