View Poll Results: Should I buy this kit?
No!
0%
Voters: 3. You may not vote on this poll
Spring & sway bar!
HTSpec Suspension Package, Stage 1, 2007-12 Acura RDX, ATLP Springs & Progress Group Sway Bar SU0012ATLP Sports-Luxury ProductsStage 1 Suspension Package
Acura RDX, 2007-12
Details
SpringsAdd an aggressive stance to your first generation RDX with approximately 1.3" lowering in front, and 1.0" lowering in rear. Slightly firmer progressive-rate springs maintain a factory-like ride with increased handling.Eibach Springs, world renowned producer of coil springs for nearly every vehicular application, had boldly produced a sport Pro-Kit Spring set for the Acura RDX, a sporty, compact luxury SUV. Unfortunately, the RDX was a slow seller, and therefore so were the springs. Eibach promptly discontinued the Pro-Kit Spring set after only one production run.Being Acura advocates, and having industry contacts at Eibach, Heeltoe Automotive saw fit to contract Eibach to do a limited run of RDX springs to be sold under the exclusive ATLP brand. Acura enthusiasts equate ATLP with style and quality; traits that perfectly describe this spring set.A killer combo featuring the two number-one suspension upgrades for the Acura RDX. We've combined the popular ATLP/Eibach RDX Pro-Kit Springs with the Progress Group's stout 22mm rear sway bar!Heeltoe Automotive is the only place to purchase sports springs for the 2007-12 RDX and it is hard to say that any more will be made once these are gone. Act now, before the ship sails!Lowering the RDX results in mild toe and camber change, so an alignment is needed after installation. Note that it is NOT enough of a change to cause dramatic alignment issues such as one gets with full coilover damper kits.Sway barProgress Suspension anti-roll bars (or sway bars) dramatically improve handling by reducing the traction-robbing body ügleanüh that rolls part of the outside tires off the pavement. Progress Groups's Sport-tuned Anti-roll bars replace skinny OEM bars and rubber bushings with larger diameter (stiffer) alloy steel bars and polyurethane bushings. More roll stiffness means less body ügleanüh, and the tires stay flatter on the pavement (larger contact patches). The result is more grip and added driver control!For best street performance results, use in conjunction with a sports springs.Progress Anti-roll bars are cold-formed in-house using custom-built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place using a precise fixture for an exact fit.
Acura RDX, 2007-12
Details
- Less body roll means more traction, faster cornering speeds, and increased driver confidence.Polyurethane bushings produce crisp response on turn-in.A rear sway bar system for 2007-2012 Acura RDX AWD vehicles. The upgraded rear anti-sway bar will be an upgraded OEM replacement, 22mm (solid) diameter, with two rate-adjustment holes in the moment arms.Installation does not impact alignment anglesRide quality is not impacted over straight roads; only noticeable while cornering or traversing uneven surfaces.
I WOULD LIKE TO BUY THIS KIT BUT I WOULD GREATLY APPRECIATE COMMENTS AND ADVICE BEFORE I PURCHASE IT! ALL INFORMATION AND PREFERENCES WOULD BE GREATLY APPRECIATED! THANK YOU SO MUCH FOR YOUR TIME IN ADVANCE!
