lifted RDX
New guy here,
I searched pretty much everywhere for info on a lift kit for the RDX and didn't find anything. I just bought a AWD 2007 tech for a winter beater and I am thinking about lifting it. In the past I built my own lift kits for a 2005 Lexus GX470 and a 2000 GMC Safari awd. Any interest on my build here? If so, I'll post pictures along the way. I'm thinking 2"-3" lift and bigger tires. |
Originally Posted by Stockstinks
(Post 15910437)
New guy here,
I searched pretty much everywhere for info on a lift kit for the RDX and didn't find anything. I just bought a AWD 2007 tech for a winter beater and I am thinking about lifting it. In the past I built my own lift kits for a 2005 Lexus GX470 and a 2000 GMC Safari awd. Any interest on my build here? If so, I'll post pictures along the way. I'm thinking 2"-3" lift and bigger tires. I am definitely interested in pics! You got my attention! |
Wondering how you build a lift kit.
The build varied depending on the vehicle .
this time I'm trying to purchase spacers that anyone can buy and easily lift their rdx |
(Post 15911272)
this time I'm trying to purchase spacers that anyone can buy and easily lift their rdx why not customize the spring rates, instead of adding a spacer. kinda ruining the engineering aspect of the springs by adding a spacer...Thus why i was ASKING how you built them. I wouldnt space springs, but that's just me |
I remember some VW cars straight from the factory had spacers in the springs and dealers forgot to take em out. :snicker:
ppl complained that their car almost killed them....because of the spacers . |
I'm interested in seeing your lifted RDX build!
1 Attachment(s)
(Post 15911369)
I've seen those.
why not customize the spring rates, instead of adding a spacer. kinda ruining the engineering aspect of the springs by adding a spacer...Thus why i was ASKING how you built them. I wouldnt space springs, but that's just me I'm not talking about adding a spacer between the coils. That certainly would be bad. I'm talking about adding the spacer above the spring in the rear and a spacer above the strut for the front. In this case it isn't going to effect the stock spring rate. Also, I'm talking about a 2" lift, nothing crazy like 4". I already ordered parts and will know by this weekend if they fit. I'll keep you posted. |
that's why I'm asking questions!!!
thanks for teaching me!! |
So I pulled a strut for measuring purposes and ordered a bunch of spacers from amazon . I will soon know if any of them fit.
I also ordered some wheel spacers thinking it might look better .
Hello
So I removed a rear spring tonight .
my goal is to come up with a dependable safe lift that anyone can buy and it would be best if you can buy it from Amazon . The upper stock spring mount is glued to the uni body frame. I didn't expect that. if it wasn't , it would have been easier to make or buy a spacer. I have the ability to machine, and weld a mount but I am trying to come up with a lift that can be purchased and installed easily . I was disappointed to see the upper spring mount was glued to the body. however , if that mount is easily ordered, I may have a simple solution . of course we could order custom length rear Springs and that is actually pretty cheap. if that is the route I'll post the length. Again , I'm trying to lift it 2" with 2" taller tires. total 3" I would go bigger, but don't want to loose too much power from the bigger and heavier tires. |
(Post 15911371)
ppl complained that their car almost killed them....because of the spacers . So the compliance of the springs in the suspension was negated and it was essentially a stiff member (heh) at each corner. As Stocksinks has mentioned, one of the ways to lift a vehicle is to add a spacer to the top of the suspension mount points. In a really simple sense, you're just lifting the entire body/cabin of the vehicle higher off the suspension/chassis creating more clearance in the wheel wells. The other way (arguably "better") is to actually replace the suspension with something of a different geometry, ie. longer shocks/springs to retain the factory upper mounts, ungapped, while creating that additional space in the wheel wells. Since you're in Houston, look at the next brodozer you come across. The loud Monster Energy drink stickered one with garish colors all over and ridiculously high lift. Chances are you'll see a huge stack of metal on the rear axle,looking like a stack of bricks, held in place with a stupidly long looking u-bolt. That's a spacer. The front end will likely have a giant metal hockey puck looking thing at the top of the strut. That's the spacer. All they're doing is moving the suspension further away from the cabin to allow Jimmy Flatbill to run his 24" matte black MetalFuel wheels with the star shaped center cap. |
Lifted RDX
7 Attachment(s)
Well I had some scrap metal laying around so I made the spacers needed for the front. (I still have to make the rears)
I made my spacers 1.800" This gave me 2 inches of lift when measures at the fender. I added cam bolts to adjust camber and had it aligned. The tires are Yokohama iceguard .255/60R18 TIRES ARE 2" TALLER THAN STOCK. They do NOT rub, but is close. I will make the rear lift this weekend and add more pictures. Sorry I couldn't find a kit that anyone could purchase and install themselves. |
Oh, I also added 1 inch wheel spacers for looks. The rear does NOT have them installed yet. I will install them when I build the rear lift. https://cimg8.ibsrv.net/gimg/acurazi...95604a811a.jpgnot exactly what I bought, but similar
So basically a 3" lift when all is said and done? Curious to hear your impressions on how this affects overall vehicle dynamics. Hopefully the added track width will help offset the added height in terms of handling (not that you'll be attacking corners or anything). Gearing isn't *too* much longer, but it's already annoyingly tall for my taste. Nice job whipping together the spacers though, looks pretty clean!
So what is the purpose of this lift? Are you planning on getting bigger and wider wheels / tires?
Originally Posted by Jakes_tl
(Post 15916621)
Originally Posted by Tomtwtwtw
(Post 15916598)
So far the handling seems fine, but I don't like the way the taller tires effected my gearing. Now at 60 mph it wants to downshift too easily. I wonder if a computer tune can change my shift points? |
Either that or just use the paddles. At this point 5th is probably useless unless you're going downhill. haha
I've been driving it in sport mode and it's been ok.
get flash pro and a down pipe this should make your setup much more responsive. more TQ at lower RPMs . get a tune also
it should be noted with larger heavier tires you should upgrade the transmission cooler in order to have the transmission live a longer life. |
RDXxx lift COMPLETED
Well I finished the lift on my RDXXX.
2" suspension lift and 2" taller tires . for the rear, I had to make a 2 piece system . Hopefully the picture help visualize . https://cimg2.ibsrv.net/gimg/acurazi...c64f98f540.jpgTapered centering post https://cimg0.ibsrv.net/gimg/acurazi...c54ba1a33f.jpgWelded both sides https://cimg7.ibsrv.net/gimg/acurazi...014857b3f9.jpgMachined lift spacer https://cimg0.ibsrv.net/gimg/acurazi...d33736fd8c.jpgMachined taper https://cimg2.ibsrv.net/gimg/acurazi...e1849eb072.jpgUpper post is on the rdx. Spacer plate fits over the centering post https://cimg9.ibsrv.net/gimg/acurazi...290da44c1c.jpgThe 2 plates are bolted together with stainless bolts https://cimg4.ibsrv.net/gimg/acurazi...de904d0627.jpgFactory rubber spring cup fits on new post https://cimg0.ibsrv.net/gimg/acurazi...0d0566f3f8.jpgI know this was dangerous. Used a strap wrapped around the coil spring with the weight of the vehicle compressing it. Then when i jacked up the frame, the spring stayed compressed allowing the space needed to install the spacer. DON'T DO THIS. I WAS PROBABLY LUCKY THAT THE STRAP HELD. https://cimg8.ibsrv.net/gimg/acurazi...97997afbb5.jpgI think they should have offered a model like this. " />3" total lift. I think they should have offered a model like this. |
Here's another shot. the taller tires fills the wheel Wells nicely . I also like the wheel spacers https://cimg9.ibsrv.net/gimg/acurazi...009399e7ce.jpgThe taller tires fill the wheel well nicely.
I was gonna point out those straps... :eek:
A spring compressor wouldn't have set you back much considering you can borrow them from the auto parts store... :poke: |
Yea, but I already had a 6 pack down and this was my only transportation. Sometimes you just gotta do it.
Just wanted to stop back by and say "that's awesome!" Nice work.
Do you have your own lathe and mill or is that an "off-the-clock" work shop? There are so many things I would love to have a lot more money, space, and knowledge to do... Even a simple lathe and mill would go a long way towards it, so I'm a little bit envious! :thumbsup: |
Originally Posted by cu2wagon
(Post 15922214)
255/55/18
I just put a set of these bad boys on my rig, living up in the north east, we need a little bit more traction/clearance... no rubbing or drivability issues thus far. It really is only a 3% difference on size but if you are looking to jack up your rig or put bigger tires- these fit on stock 18 in rims
https://cimg2.ibsrv.net/gimg/acurazi...e67ac3905e.png |
Originally Posted by REVOEVOM
(Post 15930073)
X2
So are you going to start selling kits? I'd be interested in one
I habe a 2008 RDX Tech I want to lift. Would you be willing to make a second set of this lift kit? I don't have access to the machines you used.
Great Posts
I love my 2007 Blue RDX, but agree that it's a little too low (ground clearance) and looks funny with wheels that don't fully fill out the wheel wells.
More pics and ideas are welcome. 2" sounds perfect. Nice work!! |
Lift kit
(Post 15910437)
New guy here,
I searched pretty much everywhere for info on a lift kit for the RDX and didn't find anything. I just bought a AWD 2007 tech for a winter beater and I am thinking about lifting it. In the past I built my own lift kits for a 2005 Lexus GX470 and a 2000 GMC Safari awd. Any interest on my build here? If so, I'll post pictures along the way. I'm thinking 2"-3" lift and bigger tires. So are you still making the lift kit? I have an 2007 and would like one.. whats the price? You can P M me |
HRG Engineering makes a nice spacer lift (1.5-2”).
Im currently using it and just ordered custom rear springs with a little lift and stiffer spring rate. Also about to buy bigger tires to go with some 16” wheels. |
Can't believe anyone makes lift kits for the RDX, usually these are lowered lol
So, it's time to replace the front shock assembly and the rear shock absorbers on my wife's 2007 Acura RDX. I already ordered the parts and they're in transit.
However, with all of this extra work, I'm debating on if I want to install a 2" lift from HRG. Does anyone have any feedback as to whether or not it was worth it? How has this kit been holding up? I've always thought the 1st gen RDX sat a bit too low. This kit makes them look more like an SUV, rather than a station wagon. I'd love to hear some feedback :). Additionally, I'm finding it difficult to locate a rear spring replacement DIY. Are spring compressors the only way to remove/reinstall the rear springs? It looks as if the rear springs simply seat themselves between the upper rubber mounting plate and the rear spring seat. Is this correct? The only function of the bolt I see is that it holds the rear spring mount collar to the upper rubber mounting plate. https://cimg7.ibsrv.net/gimg/acurazi...fbdc1df9cc.png |
(Post 15921001)
