DWS on Nat' wide back orded equal parada spec x
I couldn’t wait for the DWS as the stock tires are becoming slick. I can’t believe how these Michelin wear out so quickly and to make matter worse I got flat on the stock. It looks like some sort of metal stake or rod. I don’t know how I didn’t see it??
I'm confused by your post; your subject header seems to indicate that you had some sort of info about the DWS, but then your message body just talks about you getting a flat.
So, are the DWS's out of stock? B/C that's the exact tire debate I'm having right now, the DWS vs the Parada's.
Not trying to jack this thread; I've read some good things about the DWS's, how about the Yoko's?
Sorry for the confusion.
I was in the market for the DWS but they're on national wide back order. I wanted to wait for them but I got a flat the other day so I had to pull the trigger on the Yoko. I can't really comment on them just yet with less than 20 miles but it does feel smoother than the stock. The steering also feels softer too.
Let me know how those G-Max are. I did a quick search and there's no review on tirerack on them. They look more like summer tires instead of all-season by the trend pattern.
http://www.tirebuyer.com/tirebuyerwi...tedItem/803767
@DateTSX, thanks for clearing up.
@DateTSX & Senorjhawk; can you guys post updates/impressions on your respective tire choices when you get some more drive-time on them? I really like the looks of those Parada's but since the G-MAX's are cheaper, interested in how those perform as well.
Since the DWS in 235/55/18 won't be available until...what was it...early February (can anyone confirm that)? I am now leaning toward the Parada Spec-X. If you look at the survey results between the two on tire rack they are virtually identical in performance; the DWS does a little better in snow while the Yokohama does better in cornering. I'm down to 5/32 @ 40k with the OEMs and I'd like new tires before the nor' easters start rolling thru.
@DateTSX & Senorjhawk; can you guys post updates/impressions on your respective tire choices when you get some more drive-time on them? I really like the looks of those Parada's but since the G-MAX's are cheaper, interested in how those perform as well.[/QUOTE]
I'm not sure if I can give you much feedback just yet. One thing for sure, it beats driving with the spare tire for three days! The only thing I can tell that is no longer there is that this tire doesn't squeak when you turn the wheel. I always had a problem with that in the parking garage. The security guys will flag me down thinking that I'm peeling out. Ill try to do more "sprited" driving this weekend when I'm out looking for parking spot at the local mall.
Just FYI, for UHP tires Consumer Reports lists these at the top Pirelli P Zero Nero All Season, Cooper Zeon RS3-A, and Sumitomo HTR A/S. Those tires scored 82 all around. Next there is a group that scored 80 overall that includes Michelin Pilot Sport A/S Plus, Yokaham Avid Envigor, and Continental DWS.
Just throwing out some tires to consider, hope this helps!
Hey guys, just wanting to show some pic of the tires. Sorry for the big image, I'm doing this through my phone. A quick update, these Yoko are more softer than the stock. If any of have to drive over cobblestone everyday, you'll know I mean.
DateTSX & Senorjhawk, any updates on your respective tires?
Bruin
Soft and comfortable. That should pretty much sum up the Parada Spec-X. These Yoko's are a step up in terms of ride quality and smoothness. I didn't mind the firmer feel on the stock but I can tell these Yoko’s absorb the bumps and even pot holes better than the stock. I hate to say it but I hope it snow so I can really have some fun with them.
Agree 100%. Huge increase in ride quality compared to the OEMs.
I havn't done any spirited driving so I’m not sure how it handles in turns. In my case, soft and comfortable, meant it's not as bumpy or uncomfortable as you go over cracks or unpaved roads.
x2lacrosse (12-31-2011)
Pleased so far. I had nitrogen put in, they are about 36 PSI. Kinda hard for me to rate at this stage--of course they are smoother, quieter and grip much better than the 44K OEMs they replaced. And, I know it's a dumb way to judge a tire, but the tread pattern is really aggressive/good looking.
Have had the G-Max's on for week or two, but just a couple of hundred miles. Mostly dry, some wet, no snow. I will be driving around 600 miles in next few days, maybe in different weather and will report more.
While performance and safety are the most important facts, I do agree that tread pattern is important.
I got the mileage in. Much quieter/smoother than OEMs. Hard to make them lose grip/squeal. Were good in the rain, but have had no opportunity to drive them in snow. So far, very pleased.
Just got the Parada's installed (OEM size). Noticed that the max PSI is 51 (vs 44 for the OEM's), so should I still inflate to the recommended pressure or should I do a ratio of the recommended to the old max and re-apply to the new tires?
OR
@DateTSX and other Parada owners, what have you found to be the best pressures to run at? While I don't track this car, I do like to push it on the occassional back road. For the most part, this car is used for weekend trips ie mostly highway driving w/ the occassional up/down/twisty road.
OR
OR
OR
mrgold35
OR
OR
I have the Conti DWS tires and I follow the 32PSI recommendation on the sticker in the driver side door. The higher you go above the recommended 32PSI (like +38 PSI) will provide you with a stiffer ride, less traction and it may produce uneven tire wear starting in the center of the tire tread.
Took a little trip this past weekend; 100'ish miles with mostly H/W and some back roads. I have mine at 34 PSI all around.
Good:
-Yes, they're a little quieter than the stocks, but they're also new so we'll see what they sound like at 30K. But, the car is still far from quiet.
-They're a little softer, thus help absorb things like overpass joints better.
Bad:
-Don't know if it's the alignment or a combo of that and tires, but the slightest movement of the steering wheel makes the car move. This is completely diff from the stocks and pretty unsettling at highway speeds.
-While they're not horrible, I don't feel they handle as well as the stocks did. For example; on a long sweeper, had to turn the wheel much more and had to make a few adjustments while in the sweeper. I think this goes hand in hand w/ my first "Bad" statement.
-While the tread pattern looked pretty cool on Tire Rack, they don't look nearly as awesome in person. In fact, I think they're a bit homely looking.
Obviously, this is a VERY initial impression and rain/snow will determine my final verdict on these, but so far, I'm not all that happy/impressed w/ them. Guess only the long-term and some bad weather will change my opinion.
Thanks all for giving me feedback towards my tire purchase.
Good:
Bad:
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
nuldabz
09-03-2015 05:49 PM
