Dropitlow
Dropitlow
so i got the coilovers (by Megan) on last week.... after waiting till 155k miles to do new suspension i wish id have done this a lot sooner.
HOWEVER THE ONLY REASON IT WORKS WELL IS BECAUSE OF MY CUSTOM REAR UPPER CONTROL ARMS. additional $400.00
my camber settings in the rear are .9 degrees factory spec is 1 if it were dropped 2 inches without the custom kit id looked stanced and handle for shit. if you like stance life dont talk to me. i wont like you.
Oh yeah Wrench, well I am going to put a set of those Eibach Spring things on, and then whip your car...... Well, it won't touch your car cause you may as well have just built a custom car kit thing by the time you are all done with it. Looks good though, and probably drives even better.
BC Racing is a good brand, I'm sure they'll be good.
Progress sway helped on my 3G for cornering.
Prothane...not a fan of going harsh on anything rubber but I'm not sure if that's what they do or just better handling.
If you don't have a means to adjust the rear camber you're going to have a bad time when you drop the car. My Factory camber bolts wouldn't even keep my rear suspension in spec with Factory components at factory height. If you run into issues shoot me a text or phone call.
