2007 Wheel Fitment
2007 Wheel Fitment
Hello,
Maybe time for new summer tires. Came across a full wheel set from a 2019 RDX, 19” OEM wheels. Specs as follows: Bolt pattern 5x114.3
8Jx19 offset ET50. Will these fit the 2007? Tire size is 235/55/19, which looks a bit taller than 19” specs for the 2007 RDX (235/50/19).
Thanks for any input.
Tire specs for oem optional 1st gen 19” are 245/45/19. The wheels and tires from a 2019 RDX will fit no problem and as you mentioned will sit taller but affects are marginal. I myself have a NOS set of 1st gen 19” waiting for me and I’m I choosing to go 245/50 to fill the tire well a little more. I read on this forum that Acura decided 245/45 because those tires are much more common which means more options and lower prices. A 45 series is a bit too thin for my personal taste, looks and drive wise.
Hello,
As for tires; you should go 245/45 as that is the tire size on the aforementioned accessory wheels.
acuradriver925
12-21-2013 03:48 PM
S L I C K
09-25-2006 08:59 PM
