Wipers gone crazy...
Old Apr 15, 2009 | 05:33 PM
Teledatageek's Avatar
Today, the wipers decide to run at full speed by themselves. Trying the wiper stalk to any position didn't change anything nor did turning the car off and and back on again - they kept on wiping at high.
A few minutes later they stopped and wiper operation was normal with the wiper controls. It was fine for a while and then the same thing happened an hour ago or so.
They stopped on their own a few minutes later - might be my imagination but going from park to reverse seemed to turn them off as I turned around. I need to see if there's a pattern I guess. The Acura dealer had no clue.
Anyone experienced this or venture a guess? I was thinking a relay is whacky someplace... To stop them I attempted to pull the 30AMP fuse from the inside fuse box to no avail. I tried a small screwdriver, needlenose pliers, and the little fuse puller that Acura provides (seemed to big for that). Maybe a smaller needle nose is needed.
Appreciate any input.
Also - I wanted to add that I was a little surprised with my dealer... - said it would be two weeks until they had a loaner car (RDX is under warranty) and that I would have to leave it and there was no guarantee it would be looked at by 2PM after dropping off at 8AM. I told him it sounded like Honda service....
Thx.
Old Apr 16, 2009 | 08:10 AM
chipt911's Avatar
Anyone experienced this or venture a guess? I was thinking a relay is wacky someplace... To stop them I attempted to pull the 30AMP fuse from the inside fuse box to no avail. I tried a small screwdriver, needle nose pliers, and the little fuse puller that Acura provides (seemed to big for that). Maybe a smaller needle nose is needed.
Thx.
Recently, my wipers began to act erratically also. When on intermittent, they ran three to seven times in a row. The blades would not rest at the point they were supposed to either at times. I took it in and the dealer replaced the wiper motor unit which includes the controller for the wipers. I couldn't believe they had one in stock. They've worked normally since then.
Old Apr 17, 2009 | 01:25 PM
Well as odd as it sounds, I think the culprit was the DICE iPod unit. My 2nd one decided to die a slow death. Once it did, no more wiper issues.....
I also think it's weird that two of these DICE units have gone bad in a row. The posts indicate this is a pretty good unit. DICE is now suggesting that the cables be replaced, of course that means a trip to the install place. Odd that it would work perfectly for a few days and then stop. Unless the RDX has some electrical issue which I doubt....
Old May 10, 2009 | 06:16 AM
Update --- Not the DICE unit, once I replaced the DICE unit with all new cables, no problems. So must have had a bad cable blowing out units.
Wipers - The Acura dealer replaced the wiper motor as they couldn't recreate the issue. Once they did that, the problem occurred for them! Whomever they call for support suggested the wiper stalk, which they replaced. Still have the problem...
Then after pulling apart more of the dash - they suggest the vehicle has been in an accident and has deeper issues. I don't believe that it has, but.... this vehicle was an Acura buy back because of dash noise - Acura certified it to be fixed so I guess it's their problem to fix. I do still notice creaking off and on on the driver's side. Seems like the 2008's have had some frame, weld issues based on posts here.
Now I have a loaner... I guess we'll find out more on Monday.
csmeance
Jan 7, 2026 06:25 PM
TL-Rocket
Apr 29, 2023 02:33 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
wb2ee
2G RDX Problems & Fixes
Sep 22, 2015 12:00 AM
iRaw
ILX
Sep 18, 2015 12:44 PM
