Windshield washer pump fuse
haole kama'a-ina
It's number 38 (30 A) in the under-dash fuse/relay box. But if this is really out, you will have no windshield wipers either, as it controls both wash and wipe motors for the front.
Have you checked the reservior and hoses for leaks (possibly a rubber hose disconnected)?
i just had my wiper/washer switch (arm assembly on steering column) replaced under warranty. the sprayers only worked with the wipers turned off. they wouldnt work when the wipers were on. not sure what your problem is since you're asking about the fuse.
The wipers work. When i pull the arm for the washer or turn the knob for rear washer there is no noise from the pump coming on. The reservoir is full. i just had the drivers side front fender and both doors replaced due to someone hitting me. The body shop disconnected the battery and i had to reset the radio and gps. Don't know if it is related. I was hoping it was just a fuse and not the pump.
haole kama'a-ina
The washer reservior is on the passenger side, away from where you were hit. If the wipers work, but you definitely don't hear the washer motor, it's possible the wire plug was disconnected from the washer motor.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
