Where are the low & hi horns located and how to replace them?
Hi!
One of the horns stopped working and I want to replace both, low & hi, but I don't know exactly where they are located. I know that they should be somewhere close to the front bumper, thus I will appreciate any help with the process to follow for replacing them.
If one of the horns is still working, then the fuse (#12, 15 amp, in the under hood fuse box) should be OK.
The horns are just in front of the wheel wells on either side. To access the horn pull the front wheel and remove the plastic inner fender liner. The horn has a power wire connector and is grounded by the bracket to the frame.
Before buying a new horn, I would suggest testing the present one. Attach battery power to the connector terminal and ground the bracket to the frame. If the horn sounds, then clean the connector terminal and reattach it securely. Then clean the attachment bracket and frame points and reattach for a good ground.
Otherwise, the high horn is 38150-STK-A02 and the low is 38100-STK-A02.
There is one horn on each side, inside the corners of the bumper, just forward of the wheel wells. The manual does not indicate which is high and low, but you can identify them by the part number which should be printed on them.
I borrowed this pic from wspy on his excellent thread about HID installation. wspy has his bumper off and the horn is plainly visible. (Thanks wspy!)
The right side horn is circled. Ignore the Digital HID box. You don't have that.
Should be fine with just the liner. I replaced a fog light assembly last night by pulling 3 screws and 3 push-tabs and bending the plastic enough to get my chubby arms in there. The horn was clearly visible and more accessible than the fog that I had to replace.
Not to hijack this thread, but I need to replace a fog light assembly and thought I had to pull the bumper. Sounds like it can be done by just removing the liner? Can you provide some details on how you did it? Thanks
The light is only held in by two phillips screws. For easier access and better leverage instead of a screwdriver I used my ratchet with a 1/4" socket and slid a phillips bit into the socket.
The part under the bottom of the bumper "cover" is called the splash shield, and is clipped to the bottom of the "cover" and the front sub-frame cross-bar (a large diameter circular tube across the front of the car.
It would be best to simply remove the entire splash-shield. There are two clips in the passenger side wheel well which will require removal, none in the driver side wheel well. These two passenger-side clips can be accessed from under the car, but its best to jack up the front, place on jack stands, then remove the splash shield. That will also give you better access to the fog lamp - and you did not indicate which side you are replacing.
I personally don't think removing the wheel well liner will help, BUT - If you want to remove either side wheel well liner, it would be best to remove the wheel itself first. Also you will have to remove the splash guard behind the wheel. Look here for splash shield & passenger wheel liner removal:
https://acurazine.com/forums/showthread.php?t=828859
The front bumper cover is light. When I removed it, I had my wife hold it up while I unclipped it. Then I simply held and moved it to my patio and placed on some plastic garbage bags to prevent scratches. You have to unplug both fog lights before removing the cover, which can be done after unclipping (but not removing) the splash shield.
You could do all that, but I already replaced my fog light assembly as described in my post above. Bumper cover removal is absolutely not necessary, nor did I remove my wheel. Although in hindsight yanking the wheel would have given me a little more room to operate. All together it was a 30 minute job.
Thanks for the great replies. I have broken lens on the driver's side and will tackle the assembly replacement once it warms up here (if it ever does). I did buy the lens covers for the new and existing fog light lenses and hope this will be the last time!
Headlight Armor. Tough to get smooth by the edges but with elbow grease and the spatula they provided, it came out fine. I only did the replacement assembly in the house since it's been too cold to do the one on the car. We'll see how they hold up, especially at the edges.
Granted, I live in Phoenix where our hot and dry summers are the bane of all things plastic, so I'm hesitant to pull my RDX bumper if I can avoid it. In the end there is more than one way to skin a cat.
Mr Marco (03-19-2014)
TLDude876
12-28-2016 03:18 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
