Weather Stripping Winter (door bottoms)
I purchased my 09 RDX last summer, and so far, very pleased. I live in an area that has a lot of snow, and I'm noticing the weather stripping at the bottom of the doors falling off. First the passenger rear, then the drivers. Any suggestions, or has anyone else had this issue?
There are 2 paragraphs, which basically state to carefully remove the weatherstrip and clean, also clean the door bottoms. Then use p/n 72327-STK-A01 to glue it back into place, wait 12 hours to dry.
However, if only the part near the front of the door (of the car) is loose, and the door area is not too dirty - just pull it down, and use clear silicone sealer to glue it back in place. Use a paper towel to clean the weather-strip and door bottom at the front bottom of the door.
Actually, silicone will glue the entire strip, just saying you typically do not have to glue the entire length.
I also have a second suggestion: after you remove the seals, particularly the rears, you will note that there is an internal metal piece, sort of U-shaped. Its the friction that holds the seals in place.
You can squish the metal together, then put the seals back onto the doors. I did that rather than glue the seals in place, to make it easier to remove them if they get really torn.
Just remember, when you may have to remove the worn weather strip sometime inthe future, it will come free easily, but any silicone on the metal door bottom will be very difficult to remove. Just keep the foregoing in mind when applying any weather-strip cement or silicone.
IBankMouse
Jun 13, 2020 12:53 PM
SidhuSaaB
May 30, 2020 12:40 AM
4drviper
Sep 23, 2015 07:42 PM
