VSA message 134
Best to learn what set this code. If you are into working on your own car then slide under and inspect everything related to the VSA system. Halifax sensors, wiring, etc. If nothing obvious is found, use your warranty. I could not find any reference for DTC- VSA 134. Someone with a service manual will be able to look up the code.
Thanx for taking the time to reply, I was able to find the reset answer on the forum. I bought the RDX used (33,000 mi) from my daughter , I didn't think it was covered under warranty that's why I was searching the forum.
So she has 33k mi on a '10?
Clearing the code was/is not the most important issue.
The questions you need to ask are...
Warranty covers until xxxx mi and xxxx date?
What is vsa 134 code?
What caused code?
Is the vsa fully functional now?
Does the code require anything to be replaced or repaired?
What caused code?
The most common suggestion out there appears to be a speed sensor issue, but that's far from the only possibility. I'd recommend a proper diagnosis from a mechanic, otherwise you may just be throwing random parts at it without knowing the true cause.
Jamus22
06-11-2023 10:08 AM
