Transmission Problem
Old Aug 4, 2009 | 01:11 AM
somethingright's Avatar
4th Gear
Smile Transmission Problem
I got a 08 rdx, and it has always been a great ride.
But recently i found that after driving for a while, the transmission shifter heated up for some reason which i had no clues. Be more specific, the heated part was right on the display area (P R N D S). Especially around "p", it was like significantly warmer.
I am not sure if it has always been like this, but it really became annoying after i noticed that.
Is this normal?
Does anyone can explain it to me ?
Thanks for all your replies.
Old Aug 8, 2009 | 06:42 PM
mau108's Avatar
probably the light that is under there...nothing to do with the tranny.
Old Aug 26, 2009 | 10:42 PM
4th Gear
Thanks, Mau. But do u experience the same thing of your car?
Old Aug 26, 2009 | 11:01 PM
DeEjAy_LiM's Avatar
Boost Enthusiast
Never noticed this. I'll check next time after a drive.
Old Aug 27, 2009 | 07:43 AM
JMJ3rd's Avatar
'06 RL Tech
I will, too.
Old Aug 28, 2009 | 09:50 PM
4th Gear
Thank you, guys.
Old Sep 7, 2009 | 05:14 PM
DeEjAy_LiM's Avatar
Boost Enthusiast
I dunno, I've touched around the shifter and there isn't really anything hot or warm at all. 80+ degree weather and redline driving, didn't notice your problem.
Old Sep 28, 2009 | 09:26 PM
huemoua's Avatar
Is this normal?
I think this is normal. Happen all the time on mine on a long drive.
Old Sep 30, 2009 | 08:44 AM
flytldr's Avatar
It's normal.
It's excessive heat emitting from the NAV unit.
The NAV unit's cooling fan in just below the gear shifter.
If you feel very carefully, you can feel a very slight vibration through the shifter. This is also from the NAV's cooling fan.
All normal operation, nothing to worry about.
Cheers!
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
