SHAWD, VSA, ABS lights come on
Old Apr 12, 2017 | 09:28 AM
eric1910r's Avatar
8th Gear
VSA, SHAWD, ABS light come on randomly. The first time it turn on was when I was making a turn. I though it because the road was wet but it just be turning on randomly. Anybody know what it is. Car drives fine. I just turn it off and back again and it clears it out.
Old Apr 12, 2017 | 09:31 AM
how old is your battery?
and is the battery terminals and connections on tight without corrosion?
a battery that is 3 years or older, might be time to change...
additionally, loose battery connections or corroded wires will lead to momentarily power loss or warnings.
just some starting points for you
Old Apr 12, 2017 | 10:00 AM
eric1910r's Avatar
8th Gear
It's a least 2 years old. I'll check the voltage later and see if it's that and clean it. Car starts up fine
Old Apr 12, 2017 | 10:03 AM
i would tend to think it was a fluke..if it starts up fine and the lights on the dash hasnt come back.
def. check the voltage on the battery as a dying battery can throw lights on the dash for absolutely no reason at all
