Rough idle / High engine load
Old May 2, 2012 | 05:11 PM
InfamousJamous's Avatar
PM me if you need a reply
Problem:
Rough idle (idles at around 680-780 rpm but seems like it has a hard time cranking and wants to die).
High engine load (35-40% at idle in park/neutral).
Fix:
Get valves adjusted.
After having my head gasket replaced, the car would not idle normally. In Park, the engine load is high at idle (35-40% @ 720rpm) but goes down at higher rpm (5-15% @ 3000rpm). There was power up top but it was boggy below 3000rpm.
It turns out that the machine shop did not adjust the valves correctly when working on the head. At first I thought it was the throttle body and needed a PCM reset for idle learning but it turns it out it was the valves.
Old May 2, 2012 | 07:25 PM
BigHatch's Avatar
not an SUV ...a Big Hatch
dang... all buttoned up finally? seems you've been having a few issues for a while...
Old May 7, 2012 | 04:25 PM
Yeah, I got her back from the shop last week. All is good now and she purrs better than ever.
About the problem/symptoms, the engine load is now at about 30% (absolute engine load 20%) at idle according to the Torque app on my Android (I highly recommend this invaluable app and
$23 bluetooth OBDII adapter $23 bluetooth OBDII adapter
I think a more major symptom was that it was boosting at much less throttle/pedal input (full boost at less than 1/4 pedal).
So FYI.. if anybody is experiencing a rough idle and early boosting then get your valves checked.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
PortlandRL
Sep 14, 2015 12:01 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
