Power Steering pump leak?
Old Jul 23, 2023 | 12:19 AM
Flygair's Avatar
5th Gear
Hi,
I recently picked up a 2010 RDX and It's got a lot of Kms (300,000) so I've been trying to completely go over all the different mechanical checks, so far it's in good shape.
I did find that the PS fluid level was lower than the "low" indicator and there was caked fluid all around the hoses and pump.
I've washed/cleaned as much off as I can with the hope I can see what's leaking. Any advice on rebuilding vs replacement of the pump or does the line from the top leak regularly? I remember having to replace a similar line on my old BMW in the past as the rubber to metal link always seemed to leak. Thanks in advance.
Old Jul 23, 2023 | 12:42 PM
yanga001's Avatar
IS the pump noisy? I did this on my partners RDX (300k km when we bought it) as the pump was very noisy. For leaks, my families pilot had a leaking power steering pump which required replacement of 2 o rings on the pump itself. Id replace the pump only if it is noisy otherwise go for o rings to start. All parts i have put in were from various junk yards and i have not had an issue since. Hope it helps.
The power steering pump in this car is one of the easiest ones I have changed coming from older volvo's. I would not put it more than a 30 minute diy job. Keep a socket extension for 1/2in or 3/8in and use it to plug the lines while changing. Refer to honda CRV videos on how to change the pump as it is a near identical layout. Hope it helps!
Old Jul 23, 2023 | 04:48 PM
Flygair's Avatar
5th Gear
Thanks, would you happen to know if the Honda CR-V of the same years would directly swap in? Chances of me finding an RDX in the junk yard is nil.round here, CR-Vs are everywhere tho! Thanks
Old Jul 23, 2023 | 06:11 PM
Flygair's Avatar
5th Gear
So I did the full lock test and it's seeping out of the area marked on this photo. I'm hoping that would be an o-ring as it doesn't make much noise when pumping?
Old Jul 24, 2023 | 09:37 AM
I would suggest just buying all the inner rubber o rings and rebuilding rather than replace
https://www.oemacuraparts.com/v-2010...gine--p-s-pump
kap1320
Jun 8, 2018 11:47 AM
schen72
1G RDX (2007-2012)
May 25, 2018 11:37 AM
Vtbx
1G RDX (2007-2012)
Oct 24, 2016 10:07 AM
speedemon90
Mar 28, 2011 11:01 AM
Nicki
Mar 21, 2011 01:32 PM
