Poor fuel economy?
Poor fuel economy?
What are common causes? I have 181,500 km on my 2007.
I'm currently getting 16.5 L/100km (14.25 mpg). It was 13.5 L/100km (17.42 mpg) when I bought it at 157,000 km.
What is everyone else getting?
Hasn't thrown any codes.
Steadily declined over past 3 months from 13.5 L/100 km to 18.5 L/100km and then back to 16.5 L/100km.
I've maintained it meticulously.
All season Tires replaced 2000 km ago. Alignment done at the same time. - All fluids kept upto date using only Genuine Honda fluids. - Synthetic Oil changes per maintenance minder. - Spark plugs are 50,000 km old. - New battery last year. - 2 Transmission pressure switches replaced. - ECU reflashed last year.
Valve adjustment performed 13,000 km ago. Gasket was replaced.
Filters replaced.
Filters replaced.
Looks like you've covered all the obvious culprits. Is it hot where you live? A/C can drop your fuel economy by 5-15%, all other things equal (I personally have seen mine drop from ~25mpg to ~22mpg since summer hit...yeah, helps to be FWD and a highway driver). Also, seasonal fuel blend changes can affect your fuel economy. Higher ethanol content = lower mpg.
One thing I noticed - when I reverted back to stock from an ECU tune (decided I would just keep this as a plain daily), I actually gained over 2mpg on average. If you have the actual Flash Pro, consider reverting back to stock for a few tanks and see if there is a difference.
