pin code for navigation
Old 11-30-2008, 09:36 AM
lotus700's Avatar
I have a problem activating the navi/back up camera etc. it asks for pin, the problem is that the car is located overseas and there is no acura certified dealer to solve my problem. is there any way to reset the existing pin and put in the new one?
any help is deeply appreciated!
Old 11-30-2008, 11:12 AM
bryansj's Avatar
If you purchased the car new you should have the code in your documentation. However, mine was used and it wasn't included in any paperwork that I could find. Good thing is that most dealers are lazy and post the codes in the car.
Mine reset when I just got it while I was in the garage playing with all the settings for about 15 to 20 minutes. The battery got too low, but after having it off for a couple minutes I was able to get enough juice to start the car. Lesson learned.
Anyway, once it started the navigation was asking me for a four digit PIN. My dad works for car dealership and the first thing he said was to look to the glove compartment. Sure enough it was there as well as the radio code. What you have to do is open the glove compartment and look on the outer wall closest to the drivers side. The stickers aren't inside the glove compartment, but stuck to the outside and can only be seen with it open. There should be a couple stickers and one has two codes, one is long and one it four digits. The four digit code was my navigation PIN.
Old 11-30-2008, 03:37 PM
k23a1's Avatar
Interesting...
Either it's in the glove compartment, with the manuals, or you will have to be there in person to obtain this code. You are overseas, and you will not be able to obtain this code, unless you bring registration/ID to the dealer to prove that you own this vehicle.
Old 11-30-2008, 07:22 PM
littleblazer's Avatar
If you get me the radio serial number. i might get you the code.
I have account with acura dealer.
Old 08-08-2010, 06:40 AM
5th Gear
DanilaBRO's Avatar
please , help! i have the same problem as the lotus700
radio code number 25635
radio serial number GG022049
Help!!!!!
Old 11-12-2018, 07:48 AM
Dominica Gonzales's Avatar
2005 Acura MDX
I looked inside my glove compartment and there was no stickers actually and I don't know what to do it doesn't let me use the navigation system at all I could the heater or the air conditioner so I don't know what to do?
Old 11-12-2018, 08:14 PM
CSmoney28
CSmoney28's Avatar
Hey everyone, all you need is to click on this link 🤓:
https://radio-navicode.acura.com/
Have your radio serial number & vehicle vin number handy...
Old 11-13-2018, 11:03 AM
Tomtwtwtw's Avatar
To confirm, there's a difference between your radio code, your navi code, and your navi PIN. It sounds like from the language above we're talking about the actual code that you have to enter when to use the navi after power is cut, but just to be sure, the PIN is something you as the owner set to prevent anyone else from accessing personal info. Highly recommended if you program your home address, for instance. Don't want someone stealing your car and just "going home". If you're trying to reset that, you'll either need the PIN from the previous owner or have it reset at a dealership (which is what I had to do). If you're not near a dealer...you may be SOL.
Old 03-04-2020, 12:13 PM
Chuka Onyes's Avatar
Navigation pin
please this is my radio serial number 30001578.
can you assist me with the navigation pin?
Old 03-04-2020, 12:39 PM
Received 8,691 Likes on 6,705 Posts
you can do it yourself here
Old 03-04-2020, 03:24 PM
I have tried that and it keeps showing invalid VIN even when I know it’s my correct VIN. Find details VIN- 5J8TB18537A802982 Serial- 30001578 Look forward to your kind assistance.
Jamus22
06-11-2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
dirleton
09-28-2015 04:48 PM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Quick Reply: pin code for navigation
