obd2 and key immobilizer
Hi, the obd2 port as power but doesnt communicate, as anyone experienced this?
Also when inserting the key the green key light should come one and go off when the key is recognized, at the moment the green key light never comes on, so the car cranks but doesnt start (key not recognized I believe), as any one also experienced this?
Doesn't work with of any of the 4 original keys.
I have done lots of work to repair the turbo and a lot of other parts.
I finished everything and the alternator was seized, I replaced, then the starter didn't crank. Now with another alternator and starter, cranks but doesn't start. The green key symbol never comes on and the OBD2 doesn't communicate but theres power.
Will do some tests today if have the time.
Found this problem, distraction of mine some how I removed the fuse number 2, 20amp when doing tests and I put it on with the spares. Move on to next trouble and found also a connector unplugged (engine temperature)
Moving on to reasemble everything tomorow and see if everything is well.
cfli1688c1
4G TL Problems & Fixes
Nov 20, 2015 08:03 PM
