Memory Seat Problem
Old Dec 17, 2011 | 03:29 PM
R_e_X's Avatar
7th Gear
Memory Seat Problem
Wondering if anybody has experienced their memory seat buttons not working at all? Just noticed the other week my 2011 RDX memory seat buttons don't respond or light up when pressed or when unlocking the car.
I've tried everything I can think of from unlinking/linking the remotes and pressing diff combination of the memory seat buttons but nothing. Maybe I'm missing something but if I can save a trip to the dealer all the better... Thanks.
Old Dec 17, 2011 | 08:40 PM
Mr Marco's Avatar
^Happening right now in the TL. Will take it to the dealer and give you a report.
Old Dec 19, 2011 | 06:37 PM
chipmunk's Avatar
Silly question, but have you set up one of the buttons as a preset? I think the seat memory goes out everytime you lose battery power.
Old Dec 20, 2011 | 05:09 PM
R_e_X's Avatar
7th Gear
Do you mean pressing the set button and saving to Driver 1 or 2? The set button won't respond at all.... don't think I've lost battery power as the radio hasn't asked for the code.
Old Dec 20, 2011 | 07:17 PM
Mr Marco's Avatar
Wife doesn't want to take the TL in until after Christmas, so I will not have a quick answer on our issue.
Old Dec 21, 2011 | 05:26 PM
R_e_X's Avatar
7th Gear
Appreciate the update Mr Marco! If I have something new I'll post as well.
Old Jan 12, 2012 | 08:08 AM
H2EL's Avatar
Has anyone resolved this issue?
very common with the rdx, tl and mdx. Problem is the mirror acutator. My tl was doing it and i replaced the mirror actuator on the passenger side and problem fixed. Since the circuit is all linked, when you unlock your door it usually adjusts your mirrors and seats together. Try using the curb assist on each side, usally what will happen is the mirror won't return to the position its supposed to be at. P.s I work for an Acura dealer, see this all the time
Old Jan 19, 2012 | 07:59 PM
honda_nut's Avatar
2024 Genesis G70 3.3T
I have the same issue with my 3g TL. Would it also be related to the mirror actuator? Pretty sure my mirrors work correctly.
Old Mar 5, 2012 | 02:29 PM
5 Acuras's Avatar
Make it #7!
My mirrors don't change but the seat adjustment works.
Old Mar 13, 2012 | 06:48 PM
jipper's Avatar
Would this also be the fix for a 2003 cls 6sp nonnav,
That the memory seats don't work but the power seat does
Old Jun 21, 2012 | 08:21 AM
BartmanEH's Avatar
So did this fix the problem, R_e_X & Mr Marco? Did the dealer replace the mirror actuator to cure it? Y'all owe it to the AZ community to update threads with solutions.
Old Nov 2, 2014 | 09:38 AM
Tryflyguy1's Avatar
my mirrors/interior door locks/memory seats not working.close driver door the actuator goes crazy.
Old Sep 24, 2017 | 11:16 PM
Waffeey's Avatar
3G TL Drivers side mirror & memory seats not working at all. Can anyone confirm the actuator fix also solves the memory seat issue? Thanks.
Old Oct 25, 2017 | 08:04 AM
x2lacrosse's Avatar
2011 RDX having problem as well but just with the MEM buttons and positions not responding. Both mirrors respond just fine in all directions and reverse tilt-down and I've tested as much of the other electronics I can think of and everything else is working fine, just the MEM related things don't work. Anyone have any thoughts/suggestions on this?
Old Jan 27, 2018 | 03:09 AM
Waffeey's Avatar
My drivers side actuator recently went out and took my memory seat postion with it, can anyone confirm this fix?
Old Aug 3, 2019 | 09:47 PM
Andrew York's Avatar
This is easy to fix.
There's a good chance it's your mirror actuators. The easy test is to switch your mirror to L or R. Then put the car in reverse. Does the mirror you selected move? Take the car out of reverse. Did it move back to where it was before?
If it didn't move, you need to clean the guts of your mirror actuator. There are a few videos on YouTube covering this.
Hondas have the same problem. So search YouTube about it.
Old Aug 6, 2019 | 09:25 PM
CSmoney28's Avatar
CSmoney28
I changed my mirror actuator’s so many times! The memory seat control model also, wish they had more reliable parts.
Old Aug 16, 2019 | 11:46 AM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
When did they add a memory seat feature to a 1st Gen RDX?
Old Aug 19, 2019 | 12:14 PM
Tomtwtwtw's Avatar
I think the 2010 refresh got them.
Old May 18, 2021 | 12:35 AM
Jeff Bowyer's Avatar
You would think that the set button for the memory would still come on even if a problem was with the mirrors, not? I'm having the same problem with my seat memory but the fact that the light doesn't come on leads me to think it might be a fuse. Does anyone know which fuse would be responsible?
The mirrors appear to be working normally, by the way.
rockyboy
Aug 4, 2024 10:35 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
CadiGTi
Sep 14, 2015 06:37 PM
kareshi
Sep 3, 2015 03:38 PM
