Idles a little rough when not warmed up, normal?
Hello,
I recently bought a new 2008 RDX Tech, but noticed especially first start of the day in the morning after starting the car, when left in park the car idles a bit rough (but maybe that is normal, as thereafter all is fine).
Carbon Bronze Pearl 2008
I noticed similar, but rather in drive and stopped at a red light shortly after only just starting the RDX. I think it's normal. I mean, it's not significant but slightly noticable. A 4-cylinder will never idea as smooth as a V6. I wouldn't worry about it unless you feel the engine is not responding properly.
Yes, an in-line 4 will idle a little rough, especially in cold weather. I would also imagine the turbo would have some effect too in cold weather. It's just the nature of the beast.
All cars do this but noticeable more on 4 bangers (especially if you are coming from a non 4 cyl vehicle)
ECU needs to warm the car up fast and this is how it does it. Idle rpm on a cold start should sit just at or bit less then 1500 RPM, once warm should be at 700 rpm.
MrHeeltoe
20
02-23-2023 01:54 PM
DerrickW
11-15-2015 05:52 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
