how to you remove the license plate light bulb cover?
How do you change the license plate bulbs?
Hi,
Just got our RDX, how does one remove the license plate cover to change the two bulbs? Also want to replace the bulbs with whiter ones.
Thanks in advance for the help.
Just so everyone else knows:
You don't remove the exterior clear covers to change the bulbs. You change them from the inside. You pry off the cover behind the license plate on the inside of the hatch. Then you detach the bulb harnesses to access the bulbs like you do with headlights. It is not too difficult once you see it.
Brizey,
Thank you for your help. That's what i did and got it done.
Just as a tip, those plastic holders holding the bulbs have small tabs to hook up, you need to press those to remove the holder off the frame. Those little tabs are rather weak and will crack if enough force is applied.
thanks
thanks
cycdaniel
12-17-2019 10:58 AM
darksky
09-05-2015 03:11 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
