High mount brake light and Gas pedal
Old Sep 11, 2013 | 12:10 AM
littlepotato's Avatar
I have a 2009 RDX. The high mount brake light is not working. Where can I buy the OEM high mount brake light buld ? If I want to replace them by LEDs, which one(s) should I get ?
The gas paddle is falling off, I didn't find this OEM part in the store.
Thank you !
Old Sep 11, 2013 | 09:36 AM
Mr Marco's Avatar
Search first. This question has been asked before and the information you need is here already.
Led change: https://acurazine.com/forums/1g-rdx-diy-faq-161/i-want-change-all-bulb-led-any-body-help-me-869448/
Bulb #'s: https://acurazine.com/forums/1g-rdx-diy-faq-161/diy-complete-bulb-part-number-guide-w-notes-798037/
A hint on searching.
Do not use the big search box in the middle of the page.
Find the forum section you want, such as Fourth Generation RDX, DIY. Then use the drop down menu on the top of the right section of the forum that says "Search this Forum."
This will eliminate all the BS from other sections of AZ.
Old Sep 12, 2013 | 06:26 PM
Thank you! That's a really helpful hint !
mada51589
Jan 9, 2025 04:40 PM
Ny1718
Sep 11, 2015 09:21 AM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
