Help W/ Problem: Rough Start (Battery Or Alternator)?
Old Apr 3, 2011 | 12:45 AM
hl0m4n's Avatar
Question Help W/ Problem: Rough Start (Battery Or Alternator)?
i changed my spark plugs at 50k miles and the car currently has 67k miles (08 rdx). i started noticing recently that when i start the car, it has a very rough start and stutters when you start the car. when the car stutters for the second the lights on the dash go off and on before the car starts up.
is this due to battery, alternator, or some other problem? best way of diagnosis?
help much appreciated, thanks guys.
Old Apr 3, 2011 | 07:49 AM
wspy's Avatar
2008 Acura RDX
First thing is to check that the battery terminals are clean (no corrosion) and secure then go from there
Old Apr 4, 2011 | 10:37 AM
Mr Marco's Avatar
There are a dozen issues that could cause this. Take the car to a qualified mechanic and have the issue properly diagnosed.
Old Apr 4, 2011 | 10:40 AM
start with your sparkplug job.
look for disconnected sensors, might even have to go back in to see if the sparks plugs are all tightened down, if the gap didnt close, if you didnt put the coils/wires back right.
Old Apr 4, 2011 | 09:59 PM
mav238's Avatar
You only have 17000 miles on your new spark plugs, and assuming they are OEM replacement, and there are no defects with it, I would look at the injectors. Sometimes fouled injectors, and faulty ones, continues to drip a little gasoline after the car has been turned off. This can easily cause the early morning start-up engine vibrating. Run a bottle of the Chevron fuel system plus or concentrated injector cleaner, and see if it improves it. If not, just go over to Orielly's or Pep boys and have them run a quick alternator charging test. Don't assume it is the spark plugs just because the engine is vibrating.
Old Apr 5, 2011 | 08:44 AM
737 Jock's Avatar
haole kama'a-ina
+1. Definitely do this first.
If there was a problem with your sparkplug installation it's very unlikely that it would have taken 17000 miles to show up. Additionally, a sparkplug problem rough enough to shake the engine would light the MIL and send a mis-fire code. (Mis-fires are critical because of possible damage to the catalytic converter.)
If it continues after your terminals are clean and tight, take mav's advice.
The battery/charging test is free. At 67k miles and 3 years, there's a possibility you need a new battery; the OEM batteries are weak.
Old Apr 5, 2011 | 07:19 PM
littleblazer's Avatar
I got 70000 miles. OEM spark plug at 50000 No problem at all with Red Top Battery.
Old Apr 6, 2011 | 07:28 AM
wspy's Avatar
2008 Acura RDX
You gotta love em Red Tops
mada51589
Jan 9, 2025 04:40 PM
obert
Dec 14, 2015 11:36 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
Phambam12
Sep 6, 2015 06:57 PM
NSolace
Sep 3, 2015 08:14 PM
