Driver's side front window stuck down intermittently
Old May 19, 2008 | 10:57 PM
thejim's Avatar
3rd Gear
Hey guys. Just picked up my 2008 RDX this weekend and I love it so far. The only issue I've seen with it so far is, the driver's side front window seems to get stuck in the down position intermittently. It seems to resolve itself after a minute or two, but has happened to both me and my wife once each in the past 3 days.
Initially, I thought I was leaning on the door controls, chalking it up to some goofy ergonomic quirk since it was new and I was getting used to driving it. Now I know something's up. I'm taking it into the dealer for service tomorrow in the AM.
Anyone else experience anything similar?
Old May 19, 2008 | 11:53 PM
mau108's Avatar
I believe there is a sensor where it detects any obstruction, are you sure your arms or anything are not in the way?
If so yes I'd take it to the dealership and try to reproduce the problem with the service adviser there.
Old May 20, 2008 | 03:24 PM
XLR8R's Avatar
It may be related to the auto-reverse function. The auto-reverse is active only when the window is in auto-up operation; that is when the switch is pulled up and released. In auto-up, the motor will reverse if an obstacle is contacted.
If the switch is held up for manual operation the auto-reverse is de-activated.
You can troubleshoot by trying the switch first in auto-up. If the window won't go, try manual-up (de-activating auto-reverse circuitry) and see if it then moves.
Old May 20, 2008 | 08:24 PM
thejim's Avatar
3rd Gear
Turns out the reg that powers that front window is bad. So, the garage ordered the part and will likely install it tomorrow.
I'm a little pissed that the car only has 200 miles on it and something is already busted, but hey, what can you do?
jblessing
Aug 8, 2018 09:43 PM
TLDude876
Dec 28, 2016 03:18 PM
acura_dipset_tl
Jan 1, 2016 03:02 PM
PortlandRL
Sep 14, 2015 12:01 PM
08 NBP TL
Sep 8, 2015 08:49 PM
