Code
Old Jun 9, 2020 | 12:52 PM
Ivanmag's Avatar
Code
B1235 please remember, constantly this code does not know how to solve the problem, changed the flap, the sensors work fine, maybe someone came across.
Old Jun 9, 2020 | 01:39 PM
IgottaTLyousomething's Avatar
I don’t think it’s a code. I always thought that codes usually start with “P”. I’m willing to bet that it’s your regularly scheduled maintenance reminder.
B- oil and oil filter
1- rotate tires
2- replace engine and cabin filter
3- replace transmission and transfer case fluid
5- replace coolant
You can clear this reminder just like you would clear an oil change reminder light.
Old Jun 9, 2020 | 01:44 PM
+1 on it being a maintenance minder. The defintion of which can be found in your owner's manual!!!
Old Jun 9, 2020 | 01:52 PM
Ivanmag's Avatar
you are wrong, error in damper, air recirculation from the driver
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
Old Jun 9, 2020 | 02:06 PM
https://www.google.com/search?client...4dUDCAs&uact=5
:whoops:
okay
Ivanmag's Avatar
sorry but only in Russian,but I’ll try to transfer, the malfunction of the electric circuit of the air flow control system of the damper control levers or electric motor
Old Jun 9, 2020 | 02:14 PM
You’re right, that’s a legit CEL code. Google led me to these possible causes.
B1235 Possible Causes
  • Faulty Driver Side Air Mix Control Motor
  • Driver Side Air Mix Control Motor harness is open or shorted
  • Driver Side Air Mix Control Motor circuit poor electrical connection
  • Faulty Climate Control Unit
Old Jun 9, 2020 | 02:22 PM
Ivanmag's Avatar
I made the first point, I will watch the wiring, and watch the tester.
Old Jun 9, 2020 | 02:24 PM
Yeah, that’s about the extent of my usefulness. Good luck.
Old Jun 9, 2020 | 02:28 PM
Ivanmag's Avatar
Thank you, it seems to me that this climate control unit is not working properly. I will definitely write how to fix the problem.
Old Jun 9, 2020 | 02:42 PM
my link has a PDF from another car, worth a shot
sache
Jul 5, 2011 07:11 PM
AcuraCar99
Oct 26, 2009 08:42 PM
ciscogsxr
Feb 25, 2008 04:01 PM
