A/C Fan - Not Sending Air to Upper Vents
Old Apr 20, 2017 | 05:13 PM
dngvt's Avatar
3rd Gear
Hi all,
I'm a new member of the forum. Have a 2009 RDX that I bought new. Just recently, I've run into a problem I can't figure out. When the A/C is on, the air will not go up to the upper vents. It will go to the lower foot vents. Even using the mode button to try and redirect the air to upper vents, or front defrost does not work. The air is cold so I know the compressor is working. The fan works as I can raise or lower the fan speed manually. But the air is only directed to the lower foot vents. My feet are getting cold, and my body is not.
Any thoughts? Anybody else ever have this problem?
Thanks,
DNG
Old May 4, 2017 | 08:34 AM
dngvt's Avatar
3rd Gear
No ideas? Am I the only person to have this problem?
Old May 4, 2017 | 09:24 AM
DRR98's Avatar
Go to the parts section of Bernardi Acura. Enter the model, year, and then the trim level. That brings you to the assembly section. Then go to the electrical/exhaust/heater/fuel section. Then click on the assembly- heater unit. In that section you will find the parts related to your problem and diagrams to show the parts and their location.
Items #12, 13, and 14 are related to your problem.
#12 is the motor assembly for the mode- which is the button you mentioned not functioning.
Old May 4, 2017 | 11:14 AM
dngvt's Avatar
3rd Gear
DRR98,
Thanks. This is exactly what I had hoped to learn. This is much appreciated.
