AC climate control
Old May 26, 2012 | 06:27 PM
o3jeff's Avatar
AC climate control
I have a 2010 and when I set the AC to auto I have to set it down to about 60 for it to be comfortable in the car(was only 85 outside today). If I set it around 68 the fan will start out blowing on high and in a few minutes lowers itself and it it still warm in the car. The air coming out is pretty cool, my guess is a sensor is messed up?
Has anyone else run into this problem? Plan on making an appointment next week.
Old May 30, 2012 | 11:07 AM
Mr Marco's Avatar
Take 'er in. 68 is just right in my 2007.
Generally speaking you car A/C is only able to lower the air temp by about 10-15 degrees. So if it is 85 outside it should be 70 in the car. Other factors can come into play. If the vehicle sits out in the hot sun for 6-8 hours while you are at work and then you get in it to make your 15min trip home afterwards, it may not have a real chance to cool all that hot material on the inside down to a comfortable temp. The inside of your car can easily reach 125 degrees on a hot day. Tinted windows help dramatically. Mine are 25% all around (only lets in 25% of the visible light).
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
