2010 rdx
Old Aug 17, 2020 | 06:59 PM
Tarihya Harrison's Avatar
2010 rdx
Has anyone experienced humming noise coming from the power steering?
Old Aug 17, 2020 | 10:21 PM
Ron A's Avatar
Administrator
Welcome to the forums.
The following is posted at the top of the New Member Introductions forum: Welcome! Please introduce yourselves here, BUT ASK FOR HELP IN THE TECHNICAL FORUMS
Since this is a topic/technical issue which will require replies and discussion, and not an introduction, this thread has been moved to the model specific forum.
Old Aug 18, 2020 | 10:29 AM
Tomtwtwtw's Avatar
If your pump is making some noise, and there's no evidence of a leak, then I would recommend a fluid change to see if it helps. Noise is pretty common when your fluid gets old and gunky - for most that's probably around 100k miles but it could be more or less depending on your car's age and driving conditions. If you've done your own oil, you can change your own p/s fluid for the cost of 3 bottles of fluid and some rubber tubing (recommended to keep the mess down). Otherwise a reputable Honda shop should do it for under $100.
Old Aug 18, 2020 | 10:31 AM
perhaps the pump needs a refresh of all the rubber seals inside
Old Aug 23, 2020 | 06:38 PM
CSmoney28's Avatar
CSmoney28
Fluid or new unit ask the dealer they’ll let you know might have water in the line if you never changed the fluid
RDX022355
3G RDX Problems & Fixes
Jan 25, 2020 01:02 AM
jbowling
Jan 10, 2020 02:51 AM
ASolangeM
Sep 12, 2016 11:39 PM
