Unorthodox Pulley R&D by Excelerate/ Unorthodox Racing /
Old 05-30-2012, 11:36 AM
  #81
JCRDX11's Avatar
No - just the crank pulley.
Excelerate didn't have the PS pulley available for me when i ask.
Old 05-30-2012, 11:45 AM
  #82
exist12's Avatar
Did the pulley seem to make much of a difference?
Old 05-30-2012, 09:59 PM
  #83
JCRDX11's Avatar
The Rpm does seems to rev a little faster.
And the butt dyno determine it is a little more zippy but than again it could be all my other mod's kicking in. =P
Old 06-10-2012, 11:19 AM
  #84
Rotary Rocket's Avatar
This is NOT a DIY project!
I could not get the nut off with my air gun, so I went to my mechanic friend and used his professional gun. No go...it turns out you also need a professional grade air compressor as well...
My intstallation will be delayed by at least a couple of weeks, bummer.
JCRDX11, did your mechanic check to see if the belt tension was still in spec after this change? There is an indicator arrow with a range of acceptable tension range.
Old 06-10-2012, 12:09 PM
  #85
zerogravity's Avatar
^ Wow that sucks! I think I am going to leave mines stock in the engine department.
Old 06-10-2012, 03:35 PM
  #86
DRR98's Avatar
Hey Rocket,
I'm thinking a 3/4" drive socket, extension, and breaker bar with a cheater bar over that. Pull the pass side front wheel and access thru there. Stand on the cheater bar if you have to.
Anyone with a service manual could help with torque specs to give you an idea of how much force you need and the proper tools and method to remove it. Also make sure they are not left hand threads.
Old 06-11-2012, 01:53 PM
  #87
ZeroG, it is normal to run into issues when messing around with cars...hehe...
The Pully looks fantastic, almost too bling for my taste. It is a good thing you can't see it.
This is one of the very few modifcations that is truly "free" horse power with no down side. I highly recommend this modifaction.
Most people will have a mechanic do this and it is a 30 minutes max conversion. I was just giving the DIYers a heads up. Don't let me comments turn you off on this mod.
BigHatch (06-11-2012)
Old 06-11-2012, 10:46 PM
  #88
WTF?
bluecarbonfiber's Avatar
the stock crank pulley takes a special tool to hold it in place and take off.. in a pinch you can raise the vehicle and put a breaker bar on the nut and do a quick crank on the engine (it slaps against the lower control arm and doesnt hurt it).. takes about 2 times then it loosens the nut.. TQ specs are up there 130+ ft lbs i believe.. if you dont want the pinch way to do it.. you need a good impact to take it off easily 800 ft lbs gun
Old 07-15-2012, 12:37 PM
  #89
JCRDX11's Avatar
The mechanic check and there was no issue with the belt tension.
I have been driving for a few weeks now with no problems.
The car revs up a little faster. (The electric throttle is a killer *Slow*)
But I am too cheap to spend +$300 for the sprint booster.
I rather save to get the AEM FIC.
Old 07-17-2012, 07:04 PM
  #90
richard cranium
crxtype-r's Avatar
hey jcrdx11 what do you think about the sprint booster
i believe it installs behind the throttle foot pedal.
Old 07-17-2012, 08:00 PM
  #91
JCRDX11's Avatar
I didn't get the sprint booster yet. I am too cheap too.
Focus more towards the AEM FIC.
Boomslag can do a plug and play harness for me.
Tuner say that he can program the FIC on the RDX.
Only thing stopping me right now is the funds.
Old 07-18-2012, 02:49 PM
  #92
Finally got my pulley on...
The butt-dyno approves...hehe. BTW, my belt is right at the limit of proper tension.
Old 05-10-2013, 11:24 AM
  #93
user65's Avatar
Ordered the crankcase pulley and talked with XLR8 this morning. He's going to split up a UR TSX pulley kit and send me the p/s/ pulley out of it.
I'll have nothing to compare the p/s pulley against since I'll have my mechanic install both at the same time. I will do a weight comparison of the p/s pulley.
I'd be interested in doing some of the before and after tests. If I remember I will go back to DRR98's posts and record what I can.
Should be back with some results in a week and a half or so.
BigHatch (05-10-2013)
Old 05-10-2013, 10:45 PM
  #94
RDX_NRG's Avatar
JCRDX11 and Rotary Rocket.. can you guys give your fans some feedback on the crank pully now that it's been installed for a few months?
Any issues?
Rotary Rocket, when you state that your belt tension is at the limit.. do you mean at the limit of being too lose or being too tight?
Old 05-28-2013, 01:50 PM
  #95
user65's Avatar
Got the p/s and crank pulley installed a day or two after the TMIC.
Hard to tell a difference in combination with the intercooler install, but the weight savings is definitely there. It revs out slightly faster, I didn't notice a big jump myself.
The p/s pulley is probably not necessary, but it's cool to be the only RDX with one.
  • New P/S pulley weight: 8.4 oz
  • Old P/S pulley weight: 20 oz
  • New crank pulley weight: 12.4 oz
  • Old crank pulley weight: 3lbs 15.6 oz
Haven't ran into any issues but I've only driven it a week or so.
DRR98 (08-22-2013)
Old 08-02-2013, 11:06 AM
  #96
EcLm's Avatar
A lil slow on this thread but, is this crank pulley safe without a damper? User65, you've had urs for a while now, no problems so far right?
Old 08-02-2013, 01:49 PM
  #97
WTF?
ive ran my tsx with ralco rz pulleys for over 2 year no issue pulley size is about the same as the rdx
Old 08-02-2013, 05:00 PM
  #98
EcLm's Avatar
Have u guys noticed a difference in power/acceleration? When researching in other forums, some ppl said they felt a very noticeable difference and called it the best bang for their buck besides the reflash while other ppl have said that they feel no difference... How do u guys feel with it?
Old 08-02-2013, 05:44 PM
  #99
rockstar143's Avatar
Received 19,982 Likes on 14,493 Posts
I don't regret getting mine...definitely made the car feel "lighter".
EcLm (08-03-2013)
Old 08-04-2013, 12:12 AM
  #100
Any issues?
Sorry, been away for a bit.
All is fine with this mod so far. The belt is on the verge of being too loose, but still in spec.
No issues experienced, she is peepy as ever.
Old 08-08-2013, 07:59 AM
  #101
Tizzil84's Avatar
Im down put me on the list. Thanks!
Old 08-22-2013, 07:37 PM
  #102
DRR98's Avatar
[QUOTE=RDX_NRG;14473531]JCRDX11 and Rotary Rocket.. can you guys give your fans some feedback on the crank pully now that it's been installed for a few months?
Any issues?
JC returned his RDX to stock and sold it and all his mods quite a while back.
F-C
Motorsports News
33
08-22-2018 09:53 AM
lanechanger
10-13-2015 10:56 AM
0opie
09-22-2015 04:15 PM
Quick Reply: Unorthodox Pulley R&D by Excelerate/ Unorthodox Racing /
