Rdx big turbo max maf sensor
Old 04-04-2017, 07:36 PM
779civic's Avatar
I have an 07 rdx. It has a precision 5971, id1000 injectors, 3in intake, fmic, tial wg and bov, full turbo back 3in exhaust, flashpro, dw65c, and e85.
When I got this set up done. I was running off the wastegate at 10psi. Everything worked good. The other day I added another spring to get around 15-16 psi. But now I'm getting a maf circuit high code. And from what I gather. It's maxing out the maf sensor.
I have tried moving the sensor further away from the turbo. And increasing and decreasing the maf values in flashpro. But still get the code right after 6k rpm. Any help would be appreciated
Old 04-05-2017, 12:43 PM
FLETCH
TheWrench116's Avatar
what size is your maf housing?
Old 04-05-2017, 04:48 PM
779civic's Avatar
It's 3in. Someone told me if I made a 3.5 or 4in it might help.
Old 04-07-2017, 11:31 AM
FLETCH
3.5 is about the limit unless you dont care about drive ability or idle.
Old 04-07-2017, 05:02 PM
779civic's Avatar
Changed the maf sensor today with on from Acura. Still the same code. I'm going to try a smaller spring. And hope 13-14 psi will work.
Old 04-08-2017, 03:06 PM
779civic's Avatar
So today I changed springs and it still did it. Went back to the 10psi spring and still did it. So I thought what has changed. Only other thing was I recirculated the bov. I uncirculated it and now it doesn't throw that code. Going to see later if the 16psl set up will work like this.
Old 04-09-2017, 12:15 AM
thisaznboi88's Avatar
pix of build
Old 04-09-2017, 01:46 PM
779civic's Avatar
Old 04-09-2017, 04:48 PM
awesome!
Old 04-12-2017, 12:25 PM
FLETCH
interesting looking build. id step up to a larger maf housing and get the rest of the vacuum lines hooked back up. also is your fpr boost referenced? if not it wont add psi to your base pressure and it will run the risk of leaning out.
Old 04-13-2017, 03:38 PM
779civic's Avatar
Just went to a 3.5 intake and maf housing. Haven't thrown that code yet. Hope this fixes it and I can get tuned.
Old 04-22-2017, 08:35 PM
Haré romel's Avatar
i have maf code at 4500rpm-20 psi with zdx 3in housing, i run now 9 psi-7500rpm with 89 gas for moment. Try to put it as far as you can from the turbo, this help me. or try custom 3.5" housing as TheWrench116.
all look good, you don t have another code?
Old 04-24-2017, 07:14 AM
779civic's Avatar
Only code I'm getting now is from the bov not being recirculated. I can make full pulls now with the 3.5 intake.
Old 04-24-2017, 01:31 PM
FLETCH
glad that worked out.
Old 10-26-2018, 06:19 PM
PM me if you need a reply
InfamousJamous's Avatar
MAF sensor error code fix?
Does this option in the new hondata update fix this so we can do the blouch upgrade with no issues?
Old 10-26-2018, 07:42 PM
CSmoney28
CSmoney28's Avatar
Nice, build I appreciate the content of this threat.
What issues does the Blouche Performance Turbo upgrade usually cause?
Old 10-27-2018, 12:09 PM
I believe it pulls so much air that it overloads the sensor and throws a code.
Old 10-27-2018, 11:52 PM
CSmoney28
CSmoney28's Avatar
Oh wow, I wasn’t aware of this issue before...I wonder why no one has brought it up before now.
