Prothane Total kit!
Prothane Total kit!
Hey there again RDX peps! I will be sending most of my suspension pieces to Prothane in the next two weeks, so they can do some R&D work on our suspension bushing. Basically they will take out the rubber bushing and replace them with polyurethane. After the do R&D I was told that the kit would be available to the public. This is what I'm sending there for R&D.
Front lower control arm
Front sway bushing
Motor mounts
Torque mounts
Rear upper control arm
Rear lower control arm
Rear trailing arm
Rear sway bar bushing
Rear toe bar
Rear Diff bushing
Rear damper bushing
Rear cross member
Front sway bushing
Motor mounts
Torque mounts
Rear trailing arm
Rear toe bar
Rear Diff bushing
Rear damper bushing
Rear cross member
wait a second... yours photo 6 shows 2 bushings in the hole area for the rear transfer case.. my 2010 didnt get that and i know most vehicles infact dont have it.. did you order it and put it in yourself?? if you look at this video
at the 4:56 mark of the video church mentions about it
the rear sway bar will get new bushings btw
Mine came with both, and I did mention that to Prothane. However, they made a good point and said they would need the stock rear sway bar bushing, because not everybody will run the upgraded sway bar.
im jelly!! i will be deff wanting a set
RDX faN BoY
nice I am game... my 2007 only has 1 of the bushings mentioned in the video also. Im guessing the very very first rdx's had the 1 bushing? It was the first thing my brother went and looked for hahah
Very cool. I had a complete bushing kit installed in my SRT-4. Difference was definitely noticeable. Firmed things up nicely, ride really didn't suffer, although some creaks became apparent. Just have to make sure they are lubed good.
I got an email from Prothane, they're asking for VIN numbers to see what other models the kit will fit. I am assuming the kit will be for both the TB1 and TB2. Will keep everyone post as I get more info.
crxtype-r (04-13-2015)
Yep, guess the Megan coilover/shock kit and Progress RSB I'm about to slap on will be good practice for taking everything apart & reassembling it all - that shit's going on ASAP! Not waiting on the Prothane bushings, but I will get most of them when they become available. My wife's gonna hate me! Her and my daughter will need mouthpieces when they ride around...
AlLtHiNgSaCuRa (05-12-2015)
AlLtHiNgSaCuRa (06-09-2015)
KenB350z (06-09-2015)
