Jalper Down pipe
Jalper Down pipe
Ordered from Apler motorsports, full SS with an awesome weld up job. this pipe is rock solid and the turnaround time was very fast. This is my first time posting pics, so hopefully I did it right. No I just need to do the deed of taking out the PITA primary cat. Can't wait to get this mod completed
http://www.flickr.com/photos/84472116@N07/7736162786/
http://www.flickr.com/photos/84472116@N07/7736162786/[/url]
http://www.flickr.com/photos/84472116@N07/7736161860/[/url]
http://www.flickr.com/photos/84472116@N07/7736160884/in/photostream/[/url]
http://www.flickr.com/photos/84472116@N07/7736160052/in/photostream/[/url]
http://www.flickr.com/photos/84472116@N07/7736158672/in/photostream/[/url]
http://www.flickr.com/photos/84472116@N07/7736155908/in/photostream/[/url]
Now if anyone can come up with a solution to get rid of the CEL I am all ears.
It terms of the sound, there is no material difference. I have an intake so I hear more air than anything and if you listen really carefully you can hear the turbo spinning.
I did not post a response to get into a pricing argument. I am sure that your pipe is just as good and does everything that a 3" DP should. Now if someone can get us over the CEL issue without having to move the o2 bung to the mid pipe that would be awesome. I have tried the electrical approach (resistors and capacitors) and no success. Anyone tried the extenders with the 90 degree bend?
Any warranty would be cover by him plus he always follow up on any request you may have.
Might be take a day or two but that is because he is running around doing everything.
There are many actual vendors on this forum that sells the same items or similar but would never post other vendor's name to try to put them on blast about their pricing and quality.
By you posting to try to see who can offers a better price and pointing out this and that - to me it is causing drama...
2008 Acura RDX
Dan, I think that you will have to try the 90* O2 to see if it will work. I think its only the extended ones (with and without steel wool) have been tried, and they only work for a time. Extending the harness and mounting in the mid pipe (as you know) seems to be the best bet. If you try the 90* let us know the outcome..........cheers
PM me if you need a reply
Just sell yours for dirt cheap or pass the information to where you got your down pipe done so the members can get it at the shop rate directly.
Clearly you think people can't see what you are trying to do.
And by you coming back and saying that you are "trying" to help us by bashing on Jason's product so he will lower the price and make your product seems like it was any better is BS.
Anyone paying that amount is best to buy from a business than a person that can go to a shop to have these done.
Everyone can do a little research at their local area and I can guarantee someone can make it for thing for this price.
Have a little respect for other sellers instead of doing what you are doing and maybe someone would have actually purchase one from you in the future.....
Hey I have alper's full down pipe and test pipe on my car for over a year and have put over 30k miles on the car already and have had no problems at all pipes is still good no cracks. the best is I have no check engine lights till this day.
I had used the spark plug fouler trick on my mid pipe and haven't had any check light due to the down pipe since the install.
If you are going with just the downpipe - I would suggest to use the 90 degree angle o2 fouler they have on sale on Ebay.
Put a little steel wool (Coarse version) to block the sudden gush of air flow coming thru the pipes.
That should work.
If not; you can always have a local shop make you a custom 3" mid pipe and weld a o2 bung onto it.
Mid pipe is much easier to make and cheaper.
Just the down pipe is a b!tch to get too and not alot of people will have s/s donut available at their shop.
That should work.
The easiest way to order is to pickup the phone and call Alpermotor sports. Jay is a very easy guy to deal with. Google Alpermotor sports to get his phone number, if you miss him leave him a message at he will call you back
Did this multiple times, no replay. Including via email.
I really doubt that-if so; why did you say the following?
If your real intentions was to have the downpipe price go down.
Have a little respect for other sellers instead of doing what you are doing and maybe someone would have actually purchase one from you in the future.....![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
I have made my contributions to this community. Sold a couple downpipes and midpipes all with positive feedback. I have given and don't need to take anything. If it's worth my time to make some DP's then I will do so, otherwise you guys have other choices as far as producers go.
I got my first mild steel DP from Don/Jason. It cracked but I assumed responsibility even though Don stepped up and apologized for what happened.
When I say it don't look like full SS then I'm telling it like it is. I did my research, experimented with trial and error, and put in work when it comes to the RDX exhaust system. I have gone through different setups so I know what works and how they sound.
I talked to HT and he was interested in using the jig to do a production run but we haven't spoken since I picked up the intake gasket, which I still have yet to install. Maybe you guys can show HT some interest about it and we can collaborate.
Just hollow out the stock one. I swear with my hollowed out down pipe and 3inch exhaust my car sounds like a ZR1 when I start it up in the morning. Craziness...
vaprea (11-07-2012)
So you just Gut out your up stream cat? and replace the downstream cat / resonator/ piping with 3" straight pipe? Stock Muffler ?
Any way you can do a quick vid just for sound?
Do you have the check engine or emissions light?
Ok so just as followup to fix the CEL issue with only having the DP installed, please read below...
The fix for the CEL is to buy 1 90 degree bend from ebay, 2 spark plug foulers and heavy duty aluminum foil our CAT media if you have already gutted your mid pipe. First, you drill out one fouler just enough the fit the o2 sensor. Second, you put the cram the heavy duty foil/cat media between the two foulers and screw them together as tight as possible. Third, you cram the 90 degree bend with as much foil/cat media as possible and screw the fouler into the bend. Lastly, screw this setup into the o2 bung on the DP then screw the o2 sensor into the open end of the spark plug fouler. The last part takes serious manipulation and a very cold engine as you will need to loosen the DP to install this into the o2 bung without knocking into anything.
The idea here is to get as much cat media/foil between the o2 sensor and the exhaust and pull the o2 sensor as far away from the exhaust flow as possible.
I did this same thing about after alot of trial and error; no CEL after 2000 plus miles.
Hope this helps.
Hope this helps.
BigHatch (11-11-2012)
2008 Acura RDX
Ken, Start out using the smallest jet available since we cant really 'tune' our fuel system and have to rely on the factory ECU. I think that too big a jet may just make the mixture too rich and thus result in a loss of power instead.
Ah, sorry I misread.
I considered both water meth injection & the IC spray. I just hate modding my car without being able to tune the ECU. Its bothering me.
Yeah, the small one is rated at 250hp. That's all I need. I'm looking for 100 octane, because hondata said if you have higher octane you could see better performance gain. But, I will open a tread on the matter.
vaprea (02-04-2013)
08_UA7_Gr33k
02-11-2016 02:17 PM
ExcelerateRep
10-14-2015 08:20 AM
johnpancakes014
09-27-2015 12:58 PM
