HKS Turbo Timer Type-0 Install Help on RDX
Hi everyone,
I'm new to this acurazine forum and thought I'll give this forum a shot by asking if anybody has or knows how to install a HKS Turbo Timer Type-0 on a 2008 RDX.
Thank you in advance for anyone that can help.
Ukrainian RDX
Regardng the turbo-timer. IMHO it's useless at RDX. You'd better opt for HKS BOV
http://www.hondanews.com/categories/764/releases/4244
Acura's variable flow turbo is designed for maximum durability. Unlike competitor variable-vane turbo designs that put the pivot point of moving parts in very high-temperature areas of the turbo housing, the Acura variable flow turbo has fewer moving parts inside the hot turbo housing, and is designed to shield the control valve pivot from the highest temperatures.
RDX's turbocharger is positioned to the rear of the engine, close to the exhaust ports for maximum transfer of the exhaust velocity to the turbo. Water passages in the aluminum exhaust manifold help keep the temperature within the exhaust system at optimum levels for both the turbocharger and catalytic converter. The turbo housing is made of austenite stainless cast iron for durability when exposed to high-temperature exhaust gases.
When the engine is shut off, coolant continues to circulate due to thermal convection, helping to prevent long-term heat-related damage to the turbo bearings.
