brake upgrade
Old Oct 17, 2014 | 09:32 PM
crxtype-r's Avatar
richard cranium
brake upgrade
Just wanted to know what's the best brake upgrade for the 1st gen rdx . better pads with upgraded rotors , big brake kit ( 2 piece rotors? , ss brake lines , fluid . any thoughts appreciated . also weight savings? . thanks team !
Old Oct 18, 2014 | 11:38 AM
protoRDX's Avatar
Best?
1) Fast Brakes BBK based on 4 or 6 pot Wilwood calipers with 13-14" rotors and hawks pads.
2) Project Mu Acura TSX BBK customized for RDX.
Old Oct 19, 2014 | 07:43 PM
crxtype-r's Avatar
richard cranium
good stuff . thanks . need to do something ,not stopping so good right now . got the ebay special and it's not enough bite .any info helps or personal experience with a setup someone is already running . thanks guys.
Old Oct 19, 2014 | 08:58 PM
protoRDX's Avatar
Depends on your driving style and speeds you will be willing to have a confident, stable and predictable braking.
If we are talking about city driving, than a very simple upgrade to some performance rotors/pads should be enough.
If we are talking about race track experience where sometimes you need to brake from 160 to 0 an a very short distance then 4-6 pots kits and some very aggressive pads are in need.
Also it depends on your budget - a good BBK will cost you about 2k.
Old Oct 20, 2014 | 11:27 AM
UNoMyStz's Avatar
7th Gear
Has anyone looked into using the TL-S Brembo's?
Old Oct 20, 2014 | 11:36 AM
The problem with using another car's brake calipers is that you might mess up stock brake bias, effectively making you stop LONGER than current RDX brakes.
remember, each car is set up to perform differently with different sized Master cylinders and different sized rotors.
they all need to play well with each other to get shorter stopping distances.
OP never said whats wrong with his set up.
are the pads fading?
does he want more initial bite?
What does he want out of an aftermarket brake set up?
without measuring the stock braking distance, how can some one tell if they improved braking?
Old Oct 20, 2014 | 01:16 PM
bluecarbonfiber's Avatar
WTF?
^ all good factors..
i think the rdx brakes are rather small to begin with... you should ask KenB what brakes he went with and go off those.. i wouldnt go as big but deff a bigger size would help
Old Oct 20, 2014 | 05:07 PM
crxtype-r's Avatar
richard cranium
i know ken went with the k sport bbk. i have to ask him his opinion on it. I got the ebay special F & R zinc slotted rotors with ceramic pads, works ok for know (OK!?) . but for future mods want to upgrade with F & R braided lines and a good quad caliper with some nice pads (maybe carbotech pads) i run those pads with wilwood quad calipers on a 2 piece rotor on my H2 class scca crx . i think a 6 pot is over kill. but whatever they make. is what it is . just want something i can use as a daily driver but need when i get some spirited driving in. rdx 2 pots and stock pads prone to brake fade . want the reassurance. you know . input much appreciated . thanks gents !
Old Oct 20, 2014 | 05:28 PM
^ahh, cool! now we get into what you really want!!
Do the stock pads fade that bad??
the SS lines will help out a lot!!!
also try some DOT 5.1 fluid, it has a higher boiling point.
I wonder if Ksport actually put in the R&D to match brake bias on the RDX.
Old Oct 20, 2014 | 05:32 PM
crxtype-r's Avatar
richard cranium
good question . i got off tomorrow i'll look into it . good call.
Old Oct 20, 2014 | 07:29 PM
protoRDX's Avatar
Guys:
1) We already have SS braided lines in stock. And they are good.
2) DOT 5.1 is not a big help on RDX. I have Motul 5.1 in my system. Almost no difference.
Our pair rotors+pads are infamous for brake fading, thats true.
Simply because we have exactly the same size as CRV III has. However CRV weighs 250 kg less.
But the problem is not with a pair rotor+pads and even with the calipers. The problem is our MBC. Its not efficient enough and thats why people who went to install TL-S calipers said the difference is not that significant.
I would use 4pots Wilwood BBK with 2-piece rotors.
Old Oct 21, 2014 | 07:36 AM
Originally Posted by protoRDX
Guys:
so, if the master cylinder isnt big enough, what makes the wilwood bbk better?
it'll just have the same problems; as most likely, they didnt spend the R&D to match it with the Master Cylinder.
if stock is prone to brake fade; try to find the largest rotors that will fit. a larger diameter rotor will act like a heat sink and will shed heat faster.
also, one could innovate a brake cooling duct.
instead of throwing parts at something to make it better, why not improve or innovate the factory brakes...
I bet cooling them via brake duct would help out immensely.
Old Oct 21, 2014 | 07:39 AM
and wtf are you guise doing to induce brake fade??????
multiple emergency stops in a row???
Old Oct 21, 2014 | 08:22 AM
crxtype-r's Avatar
richard cranium
my brake fade was only on the stock setup, witch the factory pads suck. even with the ebay spaecial setup I don't even get fade . just with more mods want to feel safer and better stopping power. the master cylinder isn't the problem it's just finding the right pad and rotor and also justnspace ( dancing crabby) me likey. , i removed my factory fog lamps and ran flexable dryer vent hose and made some brake cooling ducts. who needs the fog lamps anywho.
Old Oct 22, 2014 | 06:05 AM
UNoMyStz's Avatar
7th Gear
All factors I'm very aware of. I know the 3rd gen TL-S ran a 4 pot Brembo caliper, unsure of what size rotor. Reason I brought it up, is I have been looking into doing a 5 lug swap on my civic, and running these with s2000 rotors. It has been done before, with great results. If able to swap simple parts, for use, this could be a great upgrade for minimal cost on the RDX, and would look killer as well. haha.
Old Oct 22, 2014 | 07:22 AM
crxtype-r's Avatar
richard cranium
do you need to change the knucle with the tl-s calipers or just get braketes and who or where to get them from , brakets that is. fast brake? and you can just make a custom line. thoughts?
Old Oct 22, 2014 | 07:56 AM
^yes, you need the knuckle from the TL-s.
again, every one thinks it will be a great upgrade; and it even feels like an upgrade with shorter pedal travel.
but in reality, the math doesnt lie.
the master cylinder has to be properly sized for the caliper.
the TL guise THOUGHT that by putting on the RL's Larger brake caliper that we would get better results.
it's not the case and we ended up getting LONGER stopping times.
Old Oct 22, 2014 | 07:59 AM
Math does not lie.
Old Oct 22, 2014 | 08:05 AM
My 2006 TL came with factory Brembos up front.
Do you guise know how bad I want to swap my ugly 1 piston rear caliper to either the STi or Evo rear brake calipers???????????????
I really want a BBK on the rear.
but guess what...
while it will bolt up and fit on the TL; it's not sized properly and will likely give me horrible results.
Just because you can and it fits; Doesnt mean you should.
Old Oct 22, 2014 | 10:43 AM
TheWrench116's Avatar
FLETCH
but guess what...
>>>>>>>>>>>>>Just because you can and it fits; Doesnt mean you should.<<<<<<<<<<<<<<<<<<
holy crap this guy has a brain!!!!!!!!!
yeah this is absolutely the case I was looking for something at one point and just dropped it because nothing was available for less then $$1,400.00 and that was the front only. I figure I'll just get the k-sport setup that ken is running and get some FAT rims and tires at that point as well so that I can use all that braking capacity when I get them.
sad fact. my 92 jeep Cherokee with 4.5 inches of lift and 32BFG A/T stopped better then my 08 RDX from 60, 70, 80, to 0 and it only had a rear disc brake swap from a 98 grand Cherokee and slotted rotors and ebc pads in the front. I got sick of doing drum brakes.
Old Oct 22, 2014 | 09:36 PM
crxtype-r's Avatar
richard cranium
dito think i'll go with the ksport that ken is running . it's the best price and design for what i need it for , and looks good now just need l/w wheels
Old Nov 5, 2014 | 01:50 PM
REVTEC's Avatar
I ended up going with EBC. Got the Redstuff pads and Ultimax rotors on all 4. It feels like it stops quicker. They look great and are much better performing than stock. I purchased them from Autoplicity for about $450 total. Took them over a month to order them from EBC for some reason, that's according to EBC themselves.
Old Nov 5, 2014 | 10:07 PM
crxtype-r's Avatar
richard cranium
went with wilwood six pot calipers and 14' 2-peice rotors and braided lines all around, should be here in 2 weeks. have to have the brackets made . gonna try to run the stock wheels .
Old Nov 5, 2014 | 10:38 PM
BigHatch's Avatar
not an SUV ...a Big Hatch
ooh document it all
Old Nov 6, 2014 | 08:05 AM
FLETCH
cant wait to see them and see what difference it makes!
Old Nov 6, 2014 | 03:05 PM
KenB350z's Avatar
Bigger isn't always better, but it's sexy and gets you off!!
Rear are on the way!!
Old Nov 8, 2014 | 01:12 AM
BigHatch's Avatar
what rears did you end up finding?
Old Nov 8, 2014 | 07:35 AM
KenB350z's Avatar
Ksport ProComp 14" 4pot Rear Big Brake Kit for 2007-2013 Honda CRV - BKHD121-443SO
Old Nov 8, 2014 | 02:33 PM
Haré romel's Avatar
Big brake always better, if have money...
Old Nov 8, 2014 | 02:35 PM
Haré romel's Avatar
take a picture went you install ... rear
Old Nov 8, 2014 | 06:10 PM
protoRDX's Avatar
Which means you will loose your parking brake functionality.
Old Nov 8, 2014 | 06:12 PM
protoRDX's Avatar
what about having the same MBC with BBK? Do you really think BBK is always better?
Old Nov 8, 2014 | 07:38 PM
KenB350z's Avatar
Ok protoRDX, these are not Honda Civics. The reason why (I'm sure you read this on a civic or a civic style rear disc BBK website) civic application says it will lose it's e-brake function, because their e-brakes are connected to the same line. However, our RDX and most SUV's have a hub style e-brake. Our e-brake is not connected to the brake line, it has it's own line.
Hub style:
Disc style:
Guess which one we have.....
Old Nov 8, 2014 | 07:46 PM
KenB350z's Avatar
I will take many pics of the rear, just like I did with the fronts!!
Old Nov 9, 2014 | 02:56 AM
KenB350z's Avatar
Civic and some other cars out there with a parking brake connected to the rear brake disc line.....
Old Nov 9, 2014 | 03:00 AM
KenB350z's Avatar
Any question's protoRDX?
Old Nov 9, 2014 | 06:46 PM
FLETCH
golf clap
Old Nov 9, 2014 | 09:39 PM
crxtype-r's Avatar
richard cranium
ditto
Old Nov 19, 2014 | 07:08 PM
Biggamee's Avatar
9th Gear
Whoa..those brakes look nice..
Old Nov 19, 2014 | 09:19 PM
Kaputnik's Avatar
Looking at a EBC & redstuff pad upgrade. Then I read on the EBC website that redstuff pads are NOT made for truck or SUV fitment. I know several companies sell them as part of a package for the RDX. Not sure what to make of this - except many folks seem to like them on the RDX. Are they intended for lighter vehicles?
