275/40/19
Old 09-07-2020, 02:21 PM
RRK0818's Avatar
275/40/19
does anyone know first hand if we can use a 19"-10" +20 wheel with a 275/40/19 tire will fit on our rdx??
Old 09-07-2020, 05:01 PM
Received 16,266 Likes on 11,974 Posts
if the car isnt lowered, I dont see why not.
there was an optional 20 inch wheel. so you wont have a problem with the diameter.
https://www.1010tires.com/Tools/Whee...et-Calculator#
this calculator says the inner clearance will be 13mm less and will extend 63mm to the outer side
Old 09-07-2020, 06:41 PM
CSmoney28
CSmoney28's Avatar
On a nineteen inch wheel height you can only go with a eight and a half inch wheel width max
Those tires would be max a 245/45/19
Old 09-07-2020, 07:08 PM
RRK0818's Avatar
Ok well that sure. Thought there was plenty of width
Old 09-07-2020, 07:09 PM
i mean i fit a 9.5 inch wide tire on my TL , and i've seen people go wider at 11"
I bet you could throw some wide ass wheels on the RDX, have it lookin mean!
Old 09-07-2020, 07:11 PM
use the online calculator I linked you.
it will give you measurements for the inner side and the outer edge. then take a tape measure or a ruler and measure how far inwards and how far outwards. if nothing is in the way, you will be able to throw that wheel on
I bet there is a lot of room for activities
Old 09-07-2020, 08:47 PM
CSmoney28
CSmoney28's Avatar
I’m talking stock look no spacers and staying inside the stock wheel wells
Old 09-08-2020, 07:19 PM
Mr Hammond's Avatar
Tire size, no problem. 10” +20 might give you a little poke, but nothing crazy. If you’re stock or Eibach, no issues. If you’re in coilovers, depends how low.
I’ve had Eibachs and BC Racing coilovers. I’ve had 19x9.5 +35 with 275/40 and 295/35, and 20x10 +40 with 275/35. All within the fenderwells. Another 20mm (~¾”) might poke out a bit. I’ve seen 10.5 with 315s and when looking straight down over the fender/wheel, they stuck out maybe ½”. Don’t remember the offset though.
I don’t think you’ll have a problem with clearance unless you’re slammed, just need to decide if that’s your style. I personally don’t get the appeal of the hella flush/stance thing, but I grew up in a different time.
Scroll through this thread: https://acurazine.com/forums/1g-rdx-...thread-682096/
justnspace (09-08-2020)
Old 09-08-2020, 09:24 PM
but that's not what this gentleman wants to do!
he wants to throw a wider wheel on the RDX!!! which is totally doable.
a wider wheel will make the RDX look mean as hell!!! a good thing!
stock specs is just too weak!
one can lower the car which cambers out the wheels so they arent sticking out past the fenders
Old 09-12-2020, 01:02 AM
CSmoney28
CSmoney28's Avatar
Yeah I know I have bc coil overs myself
Old 09-20-2020, 04:23 PM
mass978's Avatar
I run 19x9.5 wheels on my '12 RDX without spacers. Never had any clearance issues and it looks great
Old 09-22-2020, 09:03 PM
CSmoney28
CSmoney28's Avatar
I think the stock option wheels are that size...
Old 09-30-2020, 01:32 PM
Mr Hammond's Avatar
The accessory wheels are 19x8 +45.
mass978 (10-01-2020)
rdxjockey
1G RDX Tires, Wheels & Suspension
26
04-25-2023 11:59 AM
furious20
01-12-2011 03:38 PM
riovolt
11-23-2010 03:04 PM
LUTHOR-CL
14
03-24-2008 08:01 AM
White92
01-13-2008 05:33 PM
Quick Reply: 275/40/19
