Rear window spray nozzle replacement?
Does anyone know how to do this? Is it even replaceable? Right now when I turn the knob to spray fluid on the rear windshield, I just get a line of fluid flowing down the windshield...which is useless ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
Thanks,
Jeff
Thanks,
Jeff
Assuming you meant a line of fluid down the back window, then that is all I get with mine as well....and all I got with my last car with a rear sprayer. If there's a better way, I'd love to hear it.
unless you really mean like a faucet that has a leak, sounds to me like normal operation (it just sheets onto the glass in about a 1 to 2 inch wide sheet) does not spray like the front
little thing i do, you can prime the pump with some quick turns to get the fluid back there without activating the wiper (so do a few pushes on the knob but dont hold it turned), then when u see a little bit come out, go for the full spray so you get a full WET swipe with the blade, rather than a few dry scratching wipes!!
The front ones spray in a wide pattern...the back one shoots like a jet. It's not really even a "spray"...like if I turned on a faucet. It's not a wide spray at all...2 jets in a V shape whereas the front sprays a V shaped mist. I'll see if I can get a video.
d'oh! I was sure it was broken because it doesn't seem very effective this way...oh well. Now I don't have to worry about replacing the nozzle. The blade, on the other hand, needs to go.
mada51589
05-03-2022 08:54 PM
TLDude876
12-28-2016 03:18 PM
asahrts
09-04-2015 05:55 PM
