RDX L.E.D. interior lights reference - SUPERBRIGHTLEDS.com
2021 RDX A SPEC
This reference is for changing out 'most' of your interior AND license plate bulbs out to LED.
part numbers are from superbrightleds.com
The 'cool white' series is very very very pure white and i highly recommend them.
You will need:
7 x WLED-WHP:
-1 for rear storage area/hatch
-2 for courtesy lights on door (1 per door)
-2 for license plate bulbs
-2 for map lights
1 x 3022-CW4
-for rear passenger dome light
You will need:
7 x WLED-WHP:
-2 for map lights
1 x 3022-CW4
dr427 (11-04-2012)
ForesterXT,RDX Tech Owner
1 Post
Tried those style for the rear storage/hatch but did not look bright enough. They look great for the licence plate lights for sure!
Map lights, I was not sure how to pop those open. Take pictures of this part so I can give it a shot as well.
2021 RDX A SPEC
pix coming soon. however, a few comments..
1. the LED for the rear hatch area is definitely not bright enough so I have to explore some other option on that.
2. the festoon isn't too bright either ...so again, need to explore a better solution.
3. I find that the map lights are quite adequate though as well as the courtesy door lights with the above LEDs.
I am interested in door LEDs only because they (probably) draw less current (lower watt) than the OEM bulbs - because there is no way to turn off those door lights, and when I am working on or detailing the car, eventually the battery will run down. Yes, I know, it would take a long time, but I often have the door(s) open for several hours at a time.
Thanks.
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
handsom-hustla
11-13-2015 05:04 PM
