Rdx egr
2) pop up your hood, remove plastic cover from IC and throttle body will be right in front of you
3) I dont think you'll be able to complete a throttle body cleaning procedure. We have an electronic throttle body that is controlled by computer and even if you remove it and clean it you'll need to make a recalibration procedure. And for that you need to have an access to a HDS - Honda Diagnostic Scanner. Which can be found only in a dealership.
Otherwise, after cleaning and installing everything back you'll get a check engine light.
